7231 Discussions
Please explain the meaning of "#PBS -l nodes=2:ppn=1" and its use in Launching a Distributed-Memory Job?
AjayBadita
I followed the same example as mentioned in the link https://devcloud.intel.com/datacenter/learn/advanced-queue/distributed-memory-architecture. But after mentioning the nodes as 2 (#PBS -l nodes=2:ppn=1) in the distrJob2 the output says
Launching the parallel job from mother superior s001-n053...
Hello world from host s001-n053 (rank 1)!
Hello world from host s001-n101 (rank 2)!
Hello world from host s001-n053 (rank 0)!
Hello world from host s001-n101 (rank 3)!
Why is it showing four? Also please explain me the meaning of rank?
Ansif_M_Intel
PPN :Process per node
Nodes:Number of nodes requested for the job.
Rank : Serial number given to each process in the MPI job
Here you have given PPN as 1 but devcloud by default reverts it back to 2. You can find the same in your job output logs. In short, your job is launched on 2 nodes with ppn 2 each.i.e. It will run a total of 4 jobs, 2 in each node.
This explain the logs obtained.
Hope this helped.
Ansif_M_Intel
Hope this helped.
Ansif_M_Intel
Thanks for the response.
We would be glad to assist you .Please create a new thread if you face any issues.
After case closure, you will receive a survey email. We appreciate it if you can complete this survey regarding the support you received.
AjayBadita
