7302 Discussions
Possible non-thread-safe behavior in dfeast_scsrgv with parallel interval search
GiPe1978
We are running multiple FEAST eigenvalue searches (dfeast_scsrgv) in parallel on different intervals.
When run sequentially, the eigenvalues are perfectly reproducible.
When run concurrently, results vary between executions unless we protect dfeast_scsrgv with a mutex.
Environment:
- Intel MKL version: Intel oneAPI mkl 2023.1.0
- OS: Windows 2011
- Compiler:  MSVC
Fengrui
Thank you for posting in the forum!
Could you share more details how the FEAST solvers are called? Are they called in an OpenMP region with one thread for each of them? It will be great if you could share a code to reproduce this issue.
GiPe1978
Hello Fengrui,
Thank you for your reply.
To clarify, I’m not using OpenMP.
The FEAST solvers (dfeast_scsrgv) are executed in parallel threads created manually using boost::thread_group (each thread computes the eigenvalues in a different interval).
Each thread constructs its own instance of EigenValuesAndVectorsFeast, which in turn calls dfeast_scsrgv.
Here is the relevant code section:
bool
	MklSymMatrixSolver::EigenSystem(int neig, int m, double *eig, double *eiv, int &neig_found)
	if (!matrix_a_  && !matrix_b_)
		return false;
	std::vector<std::pair<double,double>> intervals;
	intervals.push_back(std::make_pair(0.1,1.5));
	intervals.push_back(std::make_pair(1.5,3));
	intervals.push_back(std::make_pair(3,6));
	intervals.push_back(std::make_pair(6,15));
	intervals.push_back(std::make_pair(15,30));
	intervals.push_back(std::make_pair(30,60));
	intervals.push_back(std::make_pair(60,120));
	intervals.push_back(std::make_pair(120,250));
	intervals.push_back(std::make_pair(250,500));
	int last = 10000;
	for (int i =500, shift =250; i<last; i+=shift)
		intervals.push_back(std::make_pair(i,i+shift));
	intervals.push_back(std::make_pair(last,1e10));
	std::vector<EigenValuesAndVectors*> eigvs;
	int saved_neig = neig;
	int tot_eigen_found= 0;
	int i_eig_start = 0;
	int i_eiv_start = 0;
	size_t grp_shift = intervals.size()>1? thread::hardware_concurrency() / 4 :1;
	size_t remaning_intervals = intervals.size();
	for (auto grp_it = intervals.begin(); grp_it!= intervals.end() && neig>0 && grp_shift>0; grp_it+=grp_shift){
		thread_group grp_thread;
		for (auto it= grp_it; it!= grp_it+grp_shift; it++){
			EigenValuesAndVectors *eigv = new EigenValuesAndVectorsFeast(matrix_a_,matrix_b_,*it,neig,m);
			eigvs.push_back(eigv);
			grp_thread.create_thread(bind(&EigenValuesAndVectors::Compute, eigv));
		grp_thread.join_all();
		for (auto it= eigvs.begin(); it!= eigvs.end() && neig>0; it++){
			EigenValuesAndVectors *eigv = *it;
			neig_found = eigv->GetNeigFound();
			bool cond = neig_found<neig;
			if ((*it)->Found()){
#ifdef _DEBUG
				int i_eig_start_bck = i_eig_start;
#endif
				eigv->FillExternalVectors(eig,eiv,i_eig_start,i_eiv_start, neig);
#ifdef _DEBUG
				std::cout<<"found "<< (cond?neig_found:neig)<<" eigenvalue\\s within  interval:"<<eigv->GetInterval().first<<"-"<<eigv->GetInterval().second<<std::endl;
				for (int i=i_eig_start_bck; i<i_eig_start ; i++)
					std::cout<<eig[i]<<std::endl;
#endif
				tot_eigen_found+=cond?neig_found:neig;
				neig-=cond?neig_found:neig;
			delete eigv;
		eigvs.clear();
		remaning_intervals-=grp_shift;
		grp_shift = remaning_intervals>grp_shift? grp_shift:remaning_intervals;
	neig_found= tot_eigen_found;
	return true;
 These are the classes used in the above code, to compute the eigenvalues in each interval:
class EigenValuesAndVectors
public:
	EigenValuesAndVectors(std::shared_ptr<MklSymMatrix> A, std::shared_ptr<MklSymMatrix> B, const std::pair<double,double> &interval, int neig, int m):
	  A_(A),B_(B), interval_(interval)
		mat_type_ = 'U';
		feastinit (fpm_);
		fpm_[1] = 3;	//number of contour points Ne = 8
		fpm_[3] = 2;	//refinement loops
		//fpm_[27] = 1;	//check positive definte
		epsout_ = 0.0;	//On output, contains the relative error on the trace: |tracei - tracei-1| /max(|emin|, |emax|)
		loop_ = 0;		//On output, contains the number of refinement loop executed. Ignored on input.
		m0_ = static_cast<int>(ceil(neig*1.5));  //Total number of eigenvalues to be computed
		leiv_ = new double [m0_ *m];
		leig_ = new double [m0_];
		res_ = new double[m0_];
		info_  = 0;
	virtual void Compute()=0;
	virtual void FillExternalVectors(double *eig, double *eiv, int &i_eig_start, int &i_eiv_start, int &neig ) = 0;
	bool Found() const
		return info_ == 0 || info_ == 3;
	int GetNeigFound() const
		return neig_found_;
	const double* GetEiv() const
		return leiv_;
	const double* GetEig() const
		return leig_;
	const std::pair<double, double> & GetInterval() const
		return interval_;
	~EigenValuesAndVectors()
		delete [] leiv_;
		delete [] leig_;
		delete [] res_;
protected:
	char mat_type_;
	MKL_INT fpm_[128]; //see https://software.intel.com/en-us/node/470386
	double epsout_;	//On output, contains the relative error on the trace: |tracei - tracei-1| /max(|emin|, |emax|)
	MKL_INT loop_;	//On output, contains the number of refinement loop executed. Ignored on input.
	MKL_INT m0_;	//Total number of eigenvalues to be computed
    const std::pair<double,double> &interval_;
	std::shared_ptr<MklSymMatrix> A_;
	std::shared_ptr<MklSymMatrix> B_;
	int neig_found_;
	double *leiv_;
	double *leig_;
	double *res_;
	MKL_INT info_;
class EigenValuesAndVectorsFeast: public EigenValuesAndVectors
public:
	EigenValuesAndVectorsFeast(std::shared_ptr<MklSymMatrix> A, std::shared_ptr<MklSymMatrix> B, const std::pair<double,double> &interval, int neig, int m):
	  EigenValuesAndVectors(A,B, interval,neig,m)
		double emin = 1/interval_.second;	//The lower bounds of the interval to be searched for eigenvalues; emin < emax.
		double emax = 1/interval_.first;	//The upper bounds of the interval to be searched for eigenvalues; emin < emax.
		int num_of_mat_row = A_->N();
		std::lock_guard<std::mutex> lock(feast_mutex_);
		dfeast_scsrgv(&mat_type_, &num_of_mat_row, B_->A(),B_->Ia(),B_->Ja(), A_->A(),A_->Ia(),A_->Ja(),
			fpm_,&epsout_,&loop_,&emin,&emax,&m0_,leig_,leiv_,&neig_found_,res_,&info_);
		bool cond = neig_found_<neig;
		int exit_loop = cond?0:neig_found_-neig;
		for (int ie= neig_found_-1; ie>= exit_loop; ie--, i_eig_start++)
			eig[i_eig_start]= 1/leig_[ie];
		int m = A_->N();
		for (int ie= (neig_found_-1)*m; ie>=exit_loop*m; ie-=m)
			for (int j = ie; j<ie+m; j++)
				eiv[i_eiv_start++]= leiv_[j];
	protected:
		static std::mutex feast_mutex_;
 The results become perfectly reproducible (same as the sequential version).
Without the mutex, the computed eigenvalues vary slightly between runs.
So it seems that dfeast_scsrgv is not fully thread-safe when called concurrently from different threads, even if the data and fpm arrays are distinct per thread.
Thanks in advance.
GiPe1978
Hello Fengrui,
bool
return false;
int last = 10000;
#ifdef _DEBUG
#endif
#ifdef _DEBUG
#endif
delete eigv;
eigvs.clear();
return true;
The classes used to compute the eigenvalues in each interval are the following:
public:
		mat_type_ = 'U';
		feastinit (fpm_);
		info_  = 0;
	bool Found() const
		return neig_found_;
		return leiv_;
		return leig_;
		return interval_;
		delete [] leiv_;
		delete [] leig_;
		delete [] res_;
protected:
	char mat_type_;
	int neig_found_;
	double *leiv_;
	double *leig_;
	double *res_;
	MKL_INT info_;
public:
		int m = A_->N();
	protected:
As mentioned, if I protect the call to dfeast_scsrgv with a global mutex, the results become perfectly reproducible (same as the sequential version). Without the mutex, the computed eigenvalues vary slightly between runs,even when mkl_set_num_threads(1) is used. So it seems that dfeast_scsrgv is not fully thread-safe when called concurrently from different threads, even if the data and fpm arrays are distinct per thread.
GiPe1978
Hello Fengrui,
bool
		return false;
	int last = 10000;
#ifdef _DEBUG
#endif
#ifdef _DEBUG
#endif
			delete eigv;
		eigvs.clear();
	return true;
public:
		mat_type_ = 'U';
		feastinit (fpm_);
		info_  = 0;
	bool Found() const
		return neig_found_;
		return leiv_;
		return leig_;
		return interval_;
		delete [] leiv_;
		delete [] leig_;
		delete [] res_;
protected:
	char mat_type_;
	int neig_found_;
	double *leiv_;
	double *leig_;
	double *res_;
	MKL_INT info_;
public:
		int m = A_->N();
	protected:
GiPe1978
Hello Fengrui,
bool
		return false;
	int last = 10000;
#ifdef _DEBUG
#endif
#ifdef _DEBUG
#endif
			delete eigv;
		eigvs.clear();
	return true;
public:
		mat_type_ = 'U';
		feastinit (fpm_);
		info_  = 0;
	bool Found() const
		return neig_found_;
		return leiv_;
		return leig_;
		return interval_;
		delete [] leiv_;
		delete [] leig_;
		delete [] res_;
protected:
	char mat_type_;
	int neig_found_;
	double *leiv_;
	double *leig_;
	double *res_;
	MKL_INT info_;
public:
		int m = A_->N();
	protected:
GiPe1978
Hello Fengrui,
bool
		return false;
	int last = 10000;
#ifdef _DEBUG
#endif
#ifdef _DEBUG
#endif
			delete eigv;
		eigvs.clear();
	return true;
public:
		mat_type_ = 'U';
		feastinit (fpm_);
		info_  = 0;
	bool Found() const
		return neig_found_;
		return leiv_;
		return leig_;
		return interval_;
		delete [] leiv_;
		delete [] leig_;
		delete [] res_;
protected:
	char mat_type_;
	int neig_found_;
	double *leiv_;
	double *leig_;
	double *res_;
	MKL_INT info_;
public:
		int m = A_->N();
	protected:
GiPe1978
Hello Fengrui,
Attached you'll finde the relevant code section.
Without the mutex, the computed eigenvalues vary slightly between runs — even when mkl_set_num_threads(1) is used.
