Code stops after a call to BLACS_GRIDEXIT
OP1
New Contributor III
The following code (built with ifx 2025.2.1 on Windows and run with 7 processes) silently crashes after the call to BLACS_GRIDEXIT on line 19 (namely, it does not execute anything past line 19).
The code is linked with the ilp64 MKL libraries for BLACS and ScaLAPACK.
Am i missing something obvious here?
PROGRAM TEST
IMPLICIT NONE (TYPE, EXTERNAL)
EXTERNAL BLACS_GRIDINIT, BLACS_GRIDINFO, BLACS_PINFO, BLACS_GET, BLACS_PCOORD, BLACS_GRIDEXIT
INTEGER(KIND = 8), EXTERNAL :: BLACS_PNUM
INTEGER(KIND = 8) :: ICTXT, MY_ID, N_PROCS, N_PROW, N_PCOL
INTEGER(KIND = 8) :: MY_ROW, MY_COL
CALL BLACS_PINFO(MY_ID, N_PROCS)
N_PROW = INT(SQRT(REAL(N_PROCS)))
N_PCOL = N_PROCS/N_PROW
CALL BLACS_GET(-1_8, 0_8, ICTXT)
CALL BLACS_GRIDINIT(ICTXT, 'C', N_PROW, N_PCOL)
CALL BLACS_GRIDINFO(ICTXT, N_PROW, N_PCOL, MY_ROW, MY_COL)
IF (MY_ID /= 6) THEN
    WRITE(*, *) 'C', MY_ID, BLACS_PNUM(ICTXT, MY_ROW, MY_COL), MY_ROW, MY_COL
END IF
CALL BLACS_GRIDEXIT(ICTXT)
CALL BLACS_GRIDINIT(ICTXT, 'R', N_PROW, N_PCOL)
    WRITE(*, *) 'R', MY_ID, BLACS_PNUM(ICTXT, MY_ROW, MY_COL), MY_ROW, MY_COL
END IF
END PROGRAM TEST
OP1
New Contributor III
Line 26 in the code above should be removed (i should have done so before posting...) but this does not modify the outcome here.
OP1
New Contributor III
Also, when did we lose the ability to edit posts?
Aleksandra_K
Does the same problem happen when running for 6 or 8 processes?
You create a grid of size 2×3 (6 positions), but you're running with 7 processes. Process number 6 has no valid grid position, which can cause the MPI to abort.
Alex
OP1
New Contributor III
I am afraid that I do not understand your reply at all. Are you saying that it is impossible to run an arbitrary number of processes for a program relying on BLACS, and that only the number of processes that match exactly the number of processes in a BLACS process grid is allowed? This is not how BLACS work!
I simplified the code a bit further:
PROGRAM TEST
EXTERNAL BLACS_GRIDINIT, BLACS_PINFO, BLACS_GET, BLACS_GRIDEXIT
WRITE(*, *) MY_ID
END PROGRAM TEST
Running the code with 7 processes, the output is:
 1
 0
 3
 5
 2
 4
Press any key to continue . . .
Why isn't process 7 printing anything here?
OP1
New Contributor III
[ignoring the fact that I should have written "process 6" in my latest message]
In fact, when I run this simplified example consecutively, multiple times, sometimes I get no output at all, sometimes only a subset of the processes 0... 5 print something. There is a randomness to it. Can you try to repeat this on your side?
Aleksandra_K
Could you share how exactly you are running the code? So that I could precisely reproduce your issue.
OP1
New Contributor III
Here is the BuildLog.htm file that is produced when building the last example above.
Aleksandra_K
We investigated your issue and confirmed that the problem is in the gridexit call. The context of rank 6 is set to -1 during blacs_gridinit -> blacs_gridmap, which causes the error when gridexit is called. You were right that it is fine to use only a subset of processes for computation. Nevertheless, it is not a bug, as this behavior of gridexit is consistent with the reference BLACS implementation (SCALAPACK: blacs_gridexit_).
Alex
Aleksandra_K
Do you have any further questions on the topic?
Aleksandra_K
I hope that you found the above explanation useful. We'll monitor this thread for another 3 days for any follow-up questions. If there's no response within that time, this thread will no longer be actively supported by Intel.
Alex
Aleksandra_K
With no response from you, this issue will no longer be tracked by Intel. If you need any additional information, please post a new question, ideally in a new thread,
Alex
