vslCopyStreamState fails
Guillaume_A_
New Contributor II
Since I upgraded MKL from 2024.0.0 to 2025.1.0 I observe crashes around the vslCopyStreamState method.
This simple program will fail on Linux OS:
#include <iostream>
#include <mkl_vsl.h>
int main()
    unsigned int scrambledSobolMaxBit = 32;
    unsigned int dimension = 399;
    int z = 0;
    for (; z < 100; z++)
        std::cout <<"z:" << z <<"\n";
        unsigned int nbParameters = 3 + scrambledSobolMaxBit * dimension;
        unsigned int* parameters = new unsigned int[nbParameters];
        int k = 0;
        parameters[k++] = dimension;
        parameters[k++] = VSL_USER_QRNG_INITIAL_VALUES;
        parameters[k++] = VSL_USER_DIRECTION_NUMBERS;
        for (; k < nbParameters; k++)
            parameters[k] = 0;
        VSLStreamStatePtr rngState;
        if (vslNewStreamEx(&rngState, VSL_BRNG_SOBOL, nbParameters, parameters) != VSL_STATUS_OK)
            std::cout <<"fail to vslNewStreamEx rngState" <<"\n";
            return 1;
        VSLStreamStatePtr tempState;
        if (vslNewStreamEx(&tempState, VSL_BRNG_SOBOL, nbParameters, parameters) != VSL_STATUS_OK)
            std::cout <<"fail to vslNewStreamEx tempState" <<"\n";
            return 1;
        delete[] parameters;
        std::cout <<"\t0\n";
        if (vslCopyStreamState(tempState, rngState) != VSL_STATUS_OK)
            std::cout << "\t0\t"<< "\tfail to copy streamState" <<"\n";
            return 1;
        // no prb if use below commented code
        if (vslDeleteStream(&tempState) != VSL_STATUS_OK)
            std::cout << "\t0\t"<< "\tfail to vslDeleteStream" <<"\n";
            return 1;
        if (vslCopyStream(&tempState, rngState) != VSL_STATUS_OK)
            std::cout << "\t0\t"<< "\tfail to vslCopyStream" <<"\n";
            return 1;
        std::cout << "\t1\n";
        vslDeleteStream(&rngState);
        vslDeleteStream(&tempState);
    return 0;
 The program crashs during the first vslCopyStreamState and show the msg:
free(): invalid pointer
Aborted (core dumped)
Useful infos:
Compilation options:
-DISOLATION_AWARE_ENABLED -std=gnu++17 -m64 -mavx -axCORE-AVX2,CORE-AVX512 -fthreadsafe-statics -fexceptions -frtti -fomit-frame-pointer -fno-strict-aliasing -O0 -g2 -gdwarf-2 -fPIE -MD -MT
Link options:
-pie -m64 -static-libgcc -static-libstdc++ -static-intel -Wl,--start-group libmkl_intel_lp64.a libmkl_sequential.a libmkl_core.a -Wl,--end-group -lpthread -ldl
Cpuinfo:
  vendor_id : AuthenticAMD
  model name : AMD EPYC-Rome Processor
OS:
  Red Hat Enterprise Linux release 9.5
Env:
  gcc == 13.1.0
  gxx == 13.1.0
  dpcpp_linux-64 == 2025.0.4
  mkl-static == 2025.1.0
Fun facts:
  • the program works fine with dimension <= 398.
  • the program works fine if comment the first std::cout (line 12).
  • the program works fine with the similar method vslCopyStream
  • the program works fine with MKL 2024.0.0
  • the same code crashs randomly on Windows 11 with an Intel(R) Xeon(R) W-11955M...
Guillaume A.
Aleksandra_K
The bug fix is included in the new release.
Alex
Aleksandra_K
Hi Guillaume,
Could you specify how you are running the code? I tried icpx with the compilation and link options which you mentioned and got correct results.
Alex
Guillaume_A_
New Contributor II
Thanks for your answer.
I am running it the most simple way, in the console: ./myprogram.out on Linux, myprogram.exe on Windows.
Did you run it on Windows or Linux OS? With an AMD or Intel CPU?
Guillaume A.
Aleksandra_K
Sorry for making the confusion, by 'running' I meant mainly compiling. I used Linux.
Guillaume_A_
New Contributor II
Oh ok, my whole compilation/link commands:
/Console # /root/bin/mf-current/bin/icpx -DISOLATION_AWARE_ENABLED -I/root/bin/mf-current/x86_64-conda-linux-gnu/include/c++/13.1.0 -I/root/bin/mf-current/x86_64-conda-linux-gnu/include/c++/13.1.0/x86_64-conda-linux-gnu -I/root/bin/mf-current/x86_64-conda-linux-gnu/sysroot/usr/include -I/root/bin/mf-current/include -std=gnu++17 -m64 -mavx -O0 -g2 -gdwarf-2 -fPIE -o myprogram.cpp.o -c myprogram.cpp
/Console # /root/bin/mf-current/bin/icpx -pie -m64 --sysroot=/root/bin/mf-current/x86_64-conda-linux-gnu/sysroot -static-libgcc -static-libstdc++ -static-intel myprogram.cpp.o -o myprogram.out -Wl,--start-group /root/bin/mf-current/lib/libmkl_intel_lp64.a /root/bin/mf-current/lib/libmkl_sequential.a /root/bin/mf-current/lib/libmkl_core.a -Wl,--end-group -lpthread -ldl
Note that I removed some option to keep it simple, but I still reproduce the crash.
gcc, g++, mkl and dpcpp have been installed with conda (miniforge).
Aleksandra_K
Hi, I eventually reproduced the issue and we will work on it internally. I'll post here with any news.
Guillaume_A_
New Contributor II
Hello, any news on this?
Guillaume A.
Aleksandra_K
I confirmed that work on this issue is in progress. I'll post here once there are updates.
Alex
Guillaume_A_
New Contributor II
Guillaume A.
Aleksandra_K
The bug has been fixed and the fix will be included in the new oneMKL release.
Alex
Aleksandra_K
Alex
Guillaume_A_
New Contributor II
Indeed, the problem is fixed with MKL 2025.3.0.
Guillaume A.
