Problem building mkl-fftw wrapper library
rob_n_
I am attempting to build the mkl-fftw wrappers, as I am compiling a program that uses FFTW3 and claims to benefit from the mkl-wrapper.  When I execute the following:
cd /opt/intel/mkl/interfaces/fftw3xf
sudo make libintel64
I get command not found:
primary@localhost: fftw3xf$sudo make libintel64
make -f  makefile lib _IA=intel64
make[1]: Entering directory `/opt/intel/composer_xe_2013_sp1.1.106/mkl/interfaces/fftw3xf'
rm -rf ./obj_intel
mkdir -p ./obj_intel
icc -vec-report0   -I../../include -I../../include/fftw     -c ../../interfaces/fftw3xf/wrappers/fftw_cleanup.c -o obj_intel/fftw_cleanup.o
make[1]: icc: Command not found
make[1]: *** [obj_intel/fftw_cleanup.o] Error 127
make[1]: Leaving directory `/opt/intel/composer_xe_2013_sp1.1.106/mkl/interfaces/fftw3xf'
make: *** [libintel64] Error 2
It would seem to my untrained eye that one of the icc flags is innapproprate.
If I run the same command with the gnu compiler, all works well. (make libintel64 compiler=gnu)
I am running Fedora20 with the latest Intel Parallel Studio XE package (ifort/icc 14.0.1) and gcc 4.8.2
I'm sure this has been addressed before; however, I searched the forum and did not find an answer to my dilema.
Appreciatively,
Robert
Gennady_F_Intel
look at the line of the message:   make[1]: icc: Command not found
you need to launch something like that first of all :
source //opt/intel/composer_xe_2013_sp1.1.106/bin/compilervars.sh intel64
to setup the compiler's environment...
rob_n_
I don't think that is the problem.  I have set up the compiler environment.
I don't believe it is saying the command "icc" is not found, I believe the compiler is saying it did not find the command/flag.  I could be wrong, as I'm not at all in my comfort zone here, but if I type icc, I do not get "command not found."
Gennady_F_Intel
I checked how it will work on my side - I don't see problem.
this is the log of thic  build: as you can see at the very bottom -- ar: creating libfftw3xf_intel.a
......]# source /opt/intel/composer_xe_2013_sp1.1.106/bin/compilervars.sh intel64
......]# ifort --version
ifort (IFORT) 14.0.1 20131008
Copyright (C) 1985-2013 Intel Corporation.  All rights reserved.
......]]# ls
fftw3xf.lst  makefile  wrappers
......]]# make libintel64
rm -rf ./obj_intel
icc -vec-report0   -I/opt/intel/composer_xe_2013_sp1.1.106/mkl/include -I/opt/intel/composer_xe_2013_sp1.1.106/mkl/include/fftw     -c /opt/intel/composer_xe_2013_sp1.1.106/mkl/interfaces/fftw3xf/wrappers/fftw_cleanup.c -o obj_intel/fftw_cleanup.o
icc -vec-report0   -I/opt/intel/composer_xe_2013_sp1.1.106/mkl/include -I/opt/intel/composer_xe_2013_sp1.1.106/mkl/include/fftw     -c /opt/intel/composer_xe_2013_sp1.1.106/mkl/interfaces/fftw3xf/wrappers/fftw_cleanup_threads.c -o obj_intel/fftw_cleanup_threads.o
icc -vec-report0   -I/opt/intel/composer_xe_2013_sp1.1.106/mkl/include -I/opt/intel/composer_xe_2013_sp1.1.106/mkl/include/fftw     -c /opt/intel/composer_xe_2013_sp1.1.106/mkl/interfaces/fftw3xf/wrappers/sfftw_plan_with_nthreads.c -o obj_intel/sfftw_plan_with_nthreads.o
icc -vec-report0   -I/opt/intel/composer_xe_2013_sp1.1.106/mkl/include -I/opt/intel/composer_xe_2013_sp1.1.106/mkl/include/fftw     -c /opt/intel/composer_xe_2013_sp1.1.106/mkl/interfaces/fftw3xf/wrappers/sfftw_print_plan.c -o obj_intel/sfftw_print_plan.o
ar rs libfftw3xf_intel.a obj_intel/fftw_cleanup.o obj_intel/fftw_cleanup_threads.o obj_intel/fftw_destroy_plan.o obj_intel/fftw_estimate_cost.o obj_intel/fftw_execute.o  ......*.o
rm -rf ./obj_intel
rob_n_
I don't know why mine does not work.   I can say I am not an isolated case. I actually have a colleague that has recently set up Ubuntu on his computer to run the same program I wish to run.  In the manual it recommends building and using these wrappers so he of course attempted this as well.  He informed me that he also had errors trying to compile the mkl-fftw3 wrappers with the intel compiler.
primary@localhost: fftw3xf$ifort -v
ifort version 14.0.1
primary@localhost: fftw3xf$icc -v
icc version 14.0.1 (gcc version 4.8.0 compatibility)
primary@localhost: fftw3xf$ls
obj_ifort/  obj_intel/  wrappers/  fftw3xf.lst  libfftw3xf_gnu.a  makefile
rm -rf ./obj_intel
You can see the gnu compiled library is present, as it compiles when I specify the gnu compiler.
Also, when I attempt to make the wrapper in dir fftw3x_cdft, neither compiler works
primary@localhost: fftw3x_cdft$sudo make libintel64 compiler=gnu
make clean mkobjdir wraplib ILP_EXT=_lp64 _IA=intel64
make[1]: Entering directory `/opt/intel/composer_xe_2013_sp1.1.106/mkl/interfaces/fftw3x_cdft'
rm -rf ./obj_intel64_lp64
rm -f ../../lib/intel64/libfftw3x_cdft_lp64.a
mkdir -p ./obj_intel64_lp64
mkdir -p ../../lib/intel64
mpicc -c -Wall     \
    -DMKL_DOUBLE -I../../include -I../../include/fftw wrappers/init_clean.c -o obj_intel64_lp64/init_clean.o
make[1]: mpicc: Command not found
make[1]: *** [obj_intel64_lp64/init_clean.o] Error 127
make[1]: Leaving directory `/opt/intel/composer_xe_2013_sp1.1.106/mkl/interfaces/fftw3x_cdft'
primary@localhost: fftw3x_cdft$sudo make libintel64 compiler=intel
mpiicc -c -Wall     \
make[1]: mpiicc: Command not found
I'm honestly not sure what the difference is between fftw3xc, fftw3xf, and fftw3x_cdft are.  I assumed the c and f corresponded to c compiler and fortran compiler, but I don't know why that would be necessary.
Dmitry_B_Intel
That happens because icc and mpiicc are not seen under sudo. You can check this by running 'sudo icc -V'. Please notice that 'sudo gcc' works.
My recommendation is not use sudo. Cd to your working directory. Set MKLROOT=/opt/intel/composer_xe_2013_sp1.1.106/mkl. Run
make -f $MKLROOT/interfaces/fftw3xc MKLROOT=$MKLROOT libintel64
fftw3xc provides wrappers for use from C/C++, fftw3xf provides wrappers for use from Fortran.
Dima
UNMESH_M_
I am having the same issue. The last comment by Dmitry did not help. Please give me some suggestion.
mwo1
This is a very old thread, but it helped me to figure out the problem, so I hope that this comment can help someone as well.
Dimitry's answer was correct, icc is indeed not found under sudo.
However, his make command did not work for me. What did was to run:
make libintel64 INSTALL_DIR=$HOME
in the
$MKLROOT/interfaces/fftw3xf
directory.
Of course I sourced the intel compiler vars first.
Cheers, Michael
