Problem for MKL10.3 matched IT++4.2
iamnono
Does anybody help me?
Software Environment: Ubuntu 10.04, itpp-4.2.tar.gz, l_mkl_10.3.2.137.tgz, GCC/G++ version 4.4.3
I have installed gcc/g++ 4,4,3 and MKL(10.3.2) in Ubuntu 10.04.
MKL directory:
/opt/intel/mkl/
/opt/intel/mkl/lib/ia32/
/opt/intel/mkl/include/
/opt/intel/composerxe-2011.2.137/mkl/
/opt/intel/composerxe-2011.2.137/mkl/lib/ia32/
/opt/intel/composerxe-2011.2.137/mkl/include/
Then I install IT++ 4.2, install command as follow:
# tar zxvf itpp-4.2.tar.gz
# cd itpp-4.2
# export LDFLAGS="-L/opt/intel/mkl/lib/ia32"
# export CPPFLAGS="-I/opt/intel/mkl/include"
# ./configure
Then happen configure error:
"configure: error: cannot find any BLAS library, which is required by LAPACK."
And, I try to use the other MKL Directory,
# export LDFLAGS="-L/opt/intel/composerxe-2011.2.137/mkl/lib/ia32"
# export CPPFLAGS="-I/opt/intel/composerxe-2011.2.137/mkl/include"
There is alse the same configure error.
Does anybody tell me the correct install method for IT++ with MKL in Ubuntu?
Or point to the correct version for IT++, MKL, G++, Linux and so on.
VipinKumar_E_Intel
What is the output of printenv?
TimP
If the application expects you to supply a complete working set of BLAS library link flags, you can retrieve one for MKL by using the link advisor posted at the top of this forum.
iamnono
The output is:
root@docomo10:/home/docomo/soft/itpp-4.2# ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for g++... g++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether accepts -g... no
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking whether we are using the GNU C++ compiler... (cached) yes
checking whether g++ accepts -g... (cached) yes
checking dependency style of g++... (cached) gcc3
checking whether we are using the GNU Fortran 77 compiler... (cached) no
checking whether accepts -g... (cached) no
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking for a sed that does not truncate output... (cached) /bin/sed
checking whether to use explicit library dependencies... no
checking for doxygen... no
checking for latex... no
checking for dvips... no
checking for gs... yes
checking for perl... /usr/bin/perl
checking for gdiff... no
checking for gnudiff... no
checking for diff... /usr/bin/diff
checking whether time.h and sys/time.h may both be included... yes
checking cmath usability... yes
checking cmath presence... yes
checking for cmath... yes
checking complex usability... yes
checking complex presence... yes
checking for complex... yes
checking ieeefp.h usability... no
checking ieeefp.h presence... no
checking for ieeefp.h... no
checking whether signgam is declared... yes
checking whether isfinite is declared... no
checking whether isinf is declared... yes
checking whether isnan is declared... yes
checking for std::isfinite... yes
checking for std::isinf... yes
checking for std::isnan... yes
checking for asinh... yes
checking for acosh... yes
checking for atanh... yes
checking for cbrt... yes
checking for erf... yes
checking for erfc... yes
checking for expm1... yes
checking for finite... yes
checking for fpclass... no
checking for isfinite... no
checking for isinf... yes
checking for isnan... yes
checking for lgamma... yes
checking for log1p... yes
checking for log2... yes
checking for rint... yes
checking for tgamma... yes
checking for sgemm_ in -lmkl_core... no
checking for dgemm_ in -lmkl_core... no
checking for sgemm_ in -lacml... no
checking for sgemm_ in -lacml_mp... no
checking for dgemm_ in -lacml... no
checking for dgemm_ in -lacml_mp... no
checking for ATL_xerbla in -latlas... no
checking for sgemm_ in -lblas... no
checking for dgemm_ in -lblas... no
You can override this error by using "--without-blas" option, but the
functionality of the IT++ library will be limited. You have been warned!
iamnono
Could you tell me an example for link advisor command,
eg. root@docomo10:/home/docomo/soft/itpp-4.2# ./configure --with-blas=
VipinKumar_E_Intel
VipinKumar_E_Intel
I successfully built IT++ with MKL 10.3on an RHEL. Actually, it automatically picked up the MKL libs as expected and mentioned in the IT++ documentation. It seems, your CPPFLAGS and LDFLAGS are not being set to point to the MKL libs. May be, you can check printing the values of those env variables by using echo and confirm it.
iamnono
Can you telll me what's your success version about RHEL, GCC/G++, IT++ with MKL 10.3 ?
VipinKumar_E_Intel
RHEL 5.1
GCC 4.1.2
IT++ 4.2
Vipin
iamnono
Thanks, I will try tochange my GCC/G++ version and Linux os version.
