Problem with Fortran version Cluster Fast Fourier Transform Compiling
Chen__Yingda
Hi all,
I get serve DftiCreateDescriptorDM initialization error in fortran version Cluster FFT functions (while I have no problem with c version compiling with similar code), could someone help me find what's going wrong?
The following code 'test.f90' is simplified after following the cdftf examples.
INCLUDE 'mkl_cdft.f90'
program main
    LOGICAL :: FAILURE
    integer, parameter :: N=2
    complex*16 :: psi(N,N)
    call fft2D(psi_in, N, FAILURE)
    if (FAILURE) then
        write(*,*)"fft cal fail"
        STOP 1
    else
        write(*,*)"call success"
    end if
end program
subroutine fft2D(psi_in, N0, FAILURE)
    USE MKL_CDFT
    USE MPI
    !!!!!!MODIFY CORRESPONDINGLY!!!!!!
    integer, intent(in) :: N0
    complex*16, intent(inout) :: psi_in(N0,N0)
    LOGICAL, intent(out) :: FAILURE
    !MPI RELATED VARIABLES
    INTEGER ROOTRANK
    INTEGER MPI_ERR
    INTEGER MPI_NPROC
    INTEGER MPI_RANK
    INTEGER COMM
    INTEGER MKL_COMM
    !pointer to descriptor
    TYPE(DFTI_DESCRIPTOR_DM), POINTER :: DESC
    INTEGER   STATUS
    INTEGER   LENGTHS(2)
    FAILURE = .FALSE.
    !!Initiate MPI by calling MPI_Init (Perform MPI initialization)
    call MPI_INIT ( MPI_ERR )
    write(*,*)"MPI INIT SUCCEED"
    COMM = MPI_COMM_WORLD
    MKL_COMM = MPI_COMM_WORLD
    CALL MPI_COMM_SIZE(COMM, MPI_NPROC, MPI_ERR)
    CALL MPI_COMM_RANK(COMM, MPI_RANK, MPI_ERR)
    IF (MPI_RANK .EQ. 0) THEN
        PRINT '(" Program is running on ",I2," processes"/)',MPI_NPROC
    END IF
    write(*,*)"N0=",N0
    LENGTHS(1)=N0
    LENGTHS(2)=N0
    !! Allocate memory for the descriptor by calling DftiCreateDescriptorDM
    STATUS = DftiCreateDescriptorDM ( COMM, DESC, DFTI_DOUBLE, DFTI_COMPLEX, 2, LENGTHS )
    IF (STATUS .NE. DFTI_NO_ERROR) THEN
        write(*,*)"STATUS=",STATUS
        FAILURE = .TRUE.
        return
    END IF
    !! Release memory allocated for a descriptor: Free DftiDM descriptor
    STATUS = DftiFreeDescriptorDM(DESC)
    !Finalize MPI
    CALL MPI_FINALIZE(MPI_ERR)
    return
end subroutine
The Makefile is given below:
#***********MAKEFILE FOR FFT BASED-CALCULATION*************
#                    Yingda Chen.2018.2.3
IFC= /opt/intel/impi/4.1.1.036/intel64/bin/mpiifort
OBJECTS= test.o
LIBES= -lmkl_cdft_core  -lmkl_intel_thread -lmkl_intel_ilp64 \
-lmkl_core -lmkl_blacs_intelmpi_ilp64 -openmp -lpthread
# -lmkl_lapack95_ilp64
OPTIMIZE= -O3
INCLUDEPATH= -I/opt/intel/composer_xe_2011_sp1.11.339/compiler/include \
-I/opt/intel/composer_xe_2011_sp1.11.339/mkl/include \
-I/opt/intel/impi/4.1.1.036/intel64/include \
#-I/opt/intel/composer_xe_2011_sp1.11.339/mkl/include/intel64/ilp64 \
LIBPATH= -L/opt/intel/composer_xe_2011_sp1.11.339/mkl/lib/intel64 \
-L/opt/intel/composer_xe_2011_sp1.11.339/compiler/lib/intel64 \
-L/opt/intel/impi/4.1.1.036/intel64/lib
test : $(OBJECTS)
	$(IFC) $^ -o $@ $(INCLUDEPATH) $(LIBPATH) $(LIBES) $(OPTIMIZE)
test.o : test.f90
	$(IFC) -c $^ $(INCLUDEPATH) $(OPTIMIZE)
.PHONY : clean cleanobj cleanmod
clean : cleanobj cleanmod
	$(RM) test
cleanobj :
	$(RM) *.o
cleanmod :
	$(RM) *.mod
The results turn out to be: (using mpirun with 2 cores)
 MPI INIT SUCCEED
 Program is running on  2 processes
 N0=           2
 STATUS=           1
 fft cal fail
 MPI INIT SUCCEED
 N0=           2
 STATUS=           1
 fft cal fail
I further check the variable STATUS, it returns 1, indicating some allocation error, however STILL CAN'T FIGURE OUT why this appears since this initialization only involve with some official declarations such as MPI_COMM_WORLD, DM type pointer as well as dimension info.
I have spent a couple of days dealing with this Cluster version of FFT functions, just hope to speed up the FFT calling (while the sequential version is working all right), so MANY MANY THANKS FOR HELPING ME DEALING WITH THIS ISSUE.
Gennady_F_Intel
pls try to link with lp64 instead of ilp64 mkl's libs and check if the problem will exist.
Gennady_F_Intel
Chen__Yingda
Hi Gennady,
this works, lp64 lib works alright. many thx and sorry for replying late
Chen__Yingda
Makefile altered as following to solve the issue:
OBJECTS= test.o
LIBES= -lmkl_cdft_core  -lmkl_intel_thread -lmkl_intel_lp64 \
-lmkl_core -lmkl_blacs_intelmpi_lp64 -openmp -lpthread
# -lmkl_lapack95_lp64
OPTIMIZE= -O3
#-I/opt/intel/composer_xe_2011_sp1.11.339/mkl/include/intel64/lp64 \
test : $(OBJECTS)
test.o : test.f90
	$(RM) test
cleanobj :
	$(RM) *.o
cleanmod :
	$(RM) *.mod
