Problem with Large Array Size in VML
Chris_L_
This is probably a simple one, but I am new to MKL and can't figure it out.  I have a large amount of time series data for which I am trying to construct a covariance matrix, and I can't seem to get my code (heavily derived from the vslscorrelationmatrix.c example) to work with N > 100k observations.  I am running Windows 7, Visual Studio 2012, am building in 64-bit Release mode, and have ILP64 set up per the Link Line Advisor instructions.
When using a large N value (even with a very small number of dimensions in the array), I get a stack overflow error when creating a new task.  I have pretty much everything in main() after the task create function commented out for debugging, but please see below.  From some tinkering, it looks like the (float*)x argument (representing the observation matrix) in vslsSSNewTask is causing the crash.  Could somebody please advise?  Thanks in advance.
#include <stdio.h>
#include "mkl.h"
#include <stdlib.h>
#include <malloc.h>
#include <stdint.h>
#include <string>
#include "D:\Program Files (x86)\Intel\Composer XE 2013 SP1\mkl\examples\examples_core\vslc\source\errcheck.inc"
//new includes
#include "stdafx.h"
#include <windows.h>
#include <conio.h>
#include <tchar.h>
#define DIM      3       /* Task dimension */
#define N        100000   /* Number of observations */
double* memmap(std::string ticker);
int main(int argc, char **argv)
	printf("JPM\n");
	double *jpm = memmap("JPM");
	for (int i = 0; i <5; i++)
		printf("%lf\n", jpm);
	printf("C\n");
	double *c = memmap("C");
		printf("%lf\n", c);
	printf("AAPL\n");
	double *aapl = memmap("AAPL");
		printf("%lf\n", aapl);
	VSLSSTaskPtr task;
    MKL_INT64 dim;
    MKL_INT64 n;
    MKL_INT64 x_storage;
    MKL_INT64 cov_storage;
    MKL_INT64 cor_storage;
	float x[DIM];
    float cov[DIM][DIM], cor[DIM][DIM];
    float mean[DIM];
    float aTmp, rTmp;
    int i, j, errcode;
    int errnums = 0;
    /***** Initializing parameters for Summary Statistics task *****/
    dim         = DIM;
    n           = N;
    x_storage   = VSL_SS_MATRIX_STORAGE_COLS;
    cov_storage = VSL_SS_MATRIX_STORAGE_FULL;
    cor_storage = VSL_SS_MATRIX_STORAGE_FULL;
    for(i = 0; i < dim; i++)
        mean = 0.0;
        for(j = 0; j < dim; j++)
            cov = 0;
            cor = 0;
	for(i=0;i<n;i++)
		x[0]=jpm;
		x[1]=c;
		x[2]=aapl;
    printf("%llu",sizeof(x));
	getchar();
    /***** Create Summary Statistics task *****/
    errcode = vslsSSNewTask( &task, &dim, &n, &x_storage, (float*)x, 0, 0 );
    CheckVslError(errcode);
    /***** Initialization of the task parameters using FULL_STORAGE for covariance/correlation matrices *****/
    errcode = vslsSSEditCovCor( task, mean, (float*)cov, &cov_storage,
        (float*)cor, &cor_storage );
    // Compute covariance/correlation matrices using FAST method
	errcode = vslsSSCompute( task,
                             VSL_SS_COV|VSL_SS_COR,
                             VSL_SS_METHOD_FAST );
	//enable above
    printf("Task dimension :         %d\n", dim);
    printf("Number of observations : %d\n\n", n);
    //Print the computed mean, covariance and correlation matrices
    printf("\nComputed means\n");
        printf("%+lf ", mean);
    printf("\n\nComputed covariance matrix          ");
    printf("Computed correlation matrix\n");
            printf("%+10lf ", cov);
        printf("   ");
            printf("%+10lf ", cor);
        printf("\n");
	printf("\nPrinting input matrix\n");
	printf("%f",x[0][0]);
	printf("\n");
	printf("%f",x[0][1]);
	printf("\n");
	printf("%f",x[0][2]);
	printf("\n");
    //Delete Summary Statistics task
    errcode = vslSSDeleteTask( &task );
    MKL_Free_Buffers();
	printf("completed\n");
	getchar();
    return 0;
	LPCTSTR pBuf;
	using namespace std;
	const std::string price = "PRICE";
	std::string hname = ticker+price;
	TCHAR *param=new TCHAR[hname.size()+1];
	param[hname.size()]=0;
	std::copy(hname.begin(),hname.end(),param);
	int dataLen = 10000000;
	HANDLE hMapFile = NULL;
    PVOID pView = NULL;
    // Try to open the named file mapping identified by the map name.
    hMapFile = OpenFileMapping(
        FILE_MAP_ALL_ACCESS,          // Read access
        FALSE,                  // Do not inherit the name
        param           // File mapping name
	pView = MapViewOfFile(
        hMapFile,               // Handle of the map object
        0,                      // High-order DWORD of the file offset
        0,            // Low-order DWORD of the file offset
        dataLen               // The number of bytes to map to view
	double *bPoint = (double*) pView;
	double *TempArr = (double*)pView;
	return TempArr;
Ilya_B_Intel
No, I am not talking about chunks now, your array is not really big enough for that.
Array of 3*100000 should be ok, but not allocated on stack.
1) float x[DIM]; to be replaced by
float *x;
x = (float*)malloc(sizeof(float)*DIM*N);
free(x);
2) x to be replaced by x[i*DIM + j]
Everything else stays as it is now.
Gennady_F_Intel
could you please attach the example as a separate .cpp file in instead of using plain text.
Chris_L_
Gennady,
Please see attached.  Thanks in advance!
Ilya_B_Intel
It looks like main problem is in the way you allocate huge array on stack:
float x[DIM];
You are probably getting stack overflow because of that. Moving to malloc/free for allocating memory for x should solve that.
Chris_L_
Hi Ilya,
Sorry to trouble you, but are you proposing to do this in chunks?  Also, I'm new to MKL, but I have been working with other, much larger objects in C++: shouldn't an array of doubles or floats with dimensions 3*100000 this be ok with IPL64?
Would you happen to have an example of malloc/free for this usage?  Thank you in advance.
Ilya_B_Intel
float *x;
free(x);
Chris_L_
Thank you Ilya, that did it!
