7299 Discussions
Problem with set MKL as default environment on MacOS
Kai181216
The source <install-dir>/setvars.sh has been run, and SETVARS_COMPLETED=1 is shown in the terminal. But the program still hint that the Intel MKL is not installed. And the document says:"On Linux and macOS systems, the installer does not add the ONEAPI_ROOT variable to the environment. To add it to the default environment, define the variable in your local shell initialization file(s) or in the system's /etc/environment file."
But I'm not sure which file should be added in the MacOS system file. Need help to set the MKL as the default environment.
ArpitaP_Intel
Hi Kai,
But the issue seems to be duplicate of the provided link
https://community.intel.com/t5/Intel-oneAPI-Math-Kernel-Library/How-to-set-up-the-environement-of-Intel-MKL-on-MacOS/m-p/1289581#M31493
We are working on your issue. Please refer the above link for further updates. We are closing this thread.
Arpita
