7303 Discussions
Problems with MKL in Microsoft Visual Studio
nak52
I just got MVS with built in MKL. MKL is linked in the tools>options>fortran>compilers>libraries and includes. As advised I also checked it in project properties>fortran>use intel mkl>parallel
In the subroutine that uses mkl i have
USE MKL95_PRECISION, ONLY: WP => DP
which gives me the following error:
error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL95_PRECISION]
Before the USE statement I also inluded:
INCLUDE 'MKL95_PRECISION.mod'
which again didn't help.
What else canI do here?
Vladimir_Koldakov__I
New Contributor III
Hello Natalia,
See the document on the web page:
http://software.intel.com/sites/products/documentation/hpc/mkl/win/MKL_UG_config_dev_env/Creating_and_Configuring_the_Intel_Visual_Fortran_Project.htm
Step 7.c: In the Property Pages window, select Configuration Properties > Linker > Input. In the right-hand part of the window, select Additional Dependencies and type the libraries required, for example, for =ia32, type mkl_intel_c.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib.
Type here mkl_lapack95.lib as well.
Vladimir
TimP
Quoting - nak52
In your installation ........MKLmakefile should help you create the .mod files, if they aren't already present somewhere such as MKLinclude. You may have to move them to a directory which is already on the default INCLUDE path, or modify the INCLUDE path to cover their present location.
Gennady_F_Intel
the same question was disscussed here
New Contributor III
Hi nak52,
- add"includeia32" directoryin the Additional Include Directories window.
- add mkl_lapack95.lib library to the project (ensure "ia32lib is in the 'Additional Library Directories')
More details see in thethread:
http://software.intel.com/en-us/forums/showthread.php?t=70693page/1/#106176
Vladimir
nak52
Hi nak52,
Vladimir
Hello Vladimir,
Thanks for the link, I am watching closely that discussion. Regarding things that you mentioned to add, I have done that already. Now I am a bit confused with "add mkl_lapack95.lib to the project". I added the mklia32lib path in the additional library directories, apparently it is not the same as "add mkl_lapack95.lib to the project". I would greatly appreciate if you let me know where exactly I should "add mkl_lapack95.lib to the project".
Thanks for your patience
Natalia
New Contributor III
Hello Natalia,
Vladimir
nak52
Quoting - tim18
The .mod files are in its place. There is something in the installation of mkl thatI am totallly missing. Compared to this installing imsl was a breeze. Still waitingfor some suggestions to make it work.
nak52
Hello Natalia,
Vladimir
Vladimir,
Many thanks for your help.
Natalia
