7260 Discussions
Program crash in mkl_avx.dll on Windows with Intel MKL 11.0
Travis_O_
One of our customers has encountered a problem with our library (NumPy) when linked against MKL version 11.0.3 on the Windows platform.    The program dies during an eigenvalue decomposition.    The problem does not show up on a build of NumPy against an older version of the MKL.
Attached are some screenshots which provide information about:
1) Where the crash occurs (mkl_avx)
2) Which instruction it seems not to like (vandpd)
3) call stack
4&5) Configuration information (Windows Version and Hardware).
The software is Anaconda 1.5 available here:  www.continuum.io  but the same problem was replicated with other versions of NumPy downloaded elsewhere.   Several machines with this kind of hardware seem to have the same problem.
SergeyKostrov
Valued Contributor II
>>...The program dies during an eigenvalue decomposition. The problem does not show up on a build of NumPy against >>an older version of the MKL... >>... >>1) Where the crash occurs (mkl_avx) >>... Travis, I see that this is the 2nd thread related to your problem. So, I reviewed screenshots again and it is Not clear for me on what MKL function the processing fails ( it looks like in some function from MKL Lapack API / there are lots of functions in that set ). Also, the 2nd screenshot has Zero length and could you upload it again? Thanks in advance.
