7302 Discussions
Progressively increasing error in calculation
S__MPay
This function calculates determinant of a matrix:
real*8 function mklDet(A)
    real*8, intent(in), dimension(:,:) :: A         !< input matrix A
    real*8, dimension(size(A,1)) :: ipiv            !! pivot indices
    integer N, info, i                              !> dimension, status
    N = size(A, 1)
    ! DGETRF computes an LU factorization of a general M-by-N matrix A
    ! using partial pivoting with row interchanges.
    call DGETRF(n, n, A, n, ipiv, info)
    !< This part of code by adopted from intel software forum topic 309460
    mklDet = 0.d0
    if (info > 0) then
        return
    else if (info < 0) then
        print *, 'Fatal error calculating determinant!'
    end if
    mklDet = 1.d0
    do i = 1, n
        if (ipiv(i).ne.i) then
            mklDet = -mklDet * a(i,i)
        else
            mklDet = mklDet * a(i,i)
        endif
    end do
end function mklDet
Now if we try to calculate determinant of a matrix with which should be zero:
!! [[6.d10,  3.d10,  5.d10];
!!  [4.d10,  4.d10,  7.d10];
!!  [12.d10, 6.d10, 10.d10]];
print *, 'zero determinant' , mklDet(reshape((/ 6.d10, 3.d10, 5.d10, 4.d10, 4.d10, 7.d10, 12.d10, 6.d10, 10.d10 /),(/3, 3/)))
as you can see the outcome is a very large number and not zero:
 zero determinant -5.329070518200751E+015
but if we use smaller numbers in the matrix
!! [[6.,  3.,  5.];
!!  [4.,  4.,  7.];
!!  [12., 6., 10.]];
print *, 'zero determinant' , mklDet(reshape((/ 6.d0, 3.d0, 5.d0, 4.d0, 4.d0, 7.d0, 12.d0, 6.d0, 10.d0 /),(/3, 3/)))
The outcome is much closer to zero:
 zero determinant  1.065814103640150E-014
How do I improve the accuracy of my calculations?
S__MPay
Update: When I try same function with quad precision the error is exactly zero:
    print *, 'zero determinant double precision' , dblMklDet(reshape((/ 6.d0, 3.d0, 5.d0, 4.d0, 4.d0, 7.d0, 12.d0, 6.d0, 10.d0 /),(/3, 3/)))
    print *, 'zero determinant  quad  precision' , qprMklDet(reshape((/ 6.q0, 3.q0, 5.q0, 4.q0, 4.q0, 7.q0, 12.q0, 6.q0, 10.q0 /),(/3, 3/)))
The output is:
 zero determinant double precision  1.065814103640150E-014
 zero determinant  quad  precision  0.000000000000000000000000000000000E+0000
I don't understand what has caused the problem in double precision.
Here is the source for quad precision version of my MklDet function:
      real(qp) function qprMklDet(A)
          real(qp), intent(in), dimension(:,:) :: A         !< input matrix A
          real(qp), dimension(size(A,1)) :: ipiv            !! pivot indices
          N = size(A, 1)
          qprMklDet = 0.d0
          if (info > 0) then
              return
          end if
          qprMklDet = 1.d0
          do i = 1, n
                  qprMklDet = -qprMklDet * a(i,i)
              else
                  qprMklDet = qprMklDet * a(i,i)
              endif
          end do
      end function qprMklDet
And qp is
      use, intrinsic :: iso_fortran_env, only: REAL64, REAL128
      implicit none
      ! C  o  n  s  t  a  n  t  s
      !integer, parameter :: sp = REAL32
      integer, parameter :: dp = REAL64
      integer, parameter :: qp = REAL128
Konstantin_A_Intel
Det calculation using LU is not stable numerically. E.g., it's clearly described at matlab page of Det function here:
https://www.mathworks.com/help/matlab/ref/det.html
So, please just avoid calling LU with singular matrices. You can first use other functions like ?gecon in order to estimate condition number of the matrix.
Konstantin
