Quadratic programming in intel math kernal lib
jeewantha_d_
I am a intel fortran commercial user and  looking for general Quadratic programming routine, but I was unable to find it in the math library. The existing routines  limited to the constrain L1 <= x <<L2. see
https://software.intel.com/en-us/node/471098#7CF8EA20-5C99-4E1D-A8D6-C6225A3F406B
In mathlab, the general solution is
with constrains
Ax<=b           Aeq. x =Beq       lb<=x<<la
https://www.mathworks.com/help/optim/ug/quadprog.html?requestedDomain=www.mathworks.com
Our constrain requirement is minimization subjected to   Ax <= b
Zhen_Z_Intel
Dear customer,
There's no QP solver in MKL. But what I feel confused is why you are using non-linear least square solver for QP constraints. The hard constraints are linear.
mecej4
MKL does not provide routines for general minimization, even for a function of one variable. The TRNLS and TRNLSBC routines can be used for QP with bound constraints, but will not be as efficient as a dedicated QP routine.
See http://plato.asu.edu/sub/pns.html and look for a solver that meets your needs. In particular, consider Gurobi and BPMPD as QP solvers, and Mosek and Knitro as a general optimization package with facilities for solving QP problems.
