Question about installation
wjiang123
Hi there,
I am trying to install MKL on my machine and got the following error:
bash: line 1: ./.././install/install: cannot execute binary file
I am wondering if there are someone getting the same problem like this? Thanks for any suggestions!
Wen
Gennady_F_Intel
Hello Wen,
The workaround is to extract install.sh and *.rpm on another 32-bit machine and copy them to target computer. Then run this shell script install.sh with the rpm name as a parameter
And if it will not help you
I would recommend you submit the issue against MKL to Premier support( https://premier.intel.com/ )
--Gennady
wjiang123
Thanks, Gennady. But I cannot find *.rpm file in the unziped package. What is it?
Nikolay_L_Intel
Could you try to start this install on another machine? If it's possible and successful, please interrupt install process when it will ask you about destination path. Then you can discover new /tmp/install_temp. folder. It contains the product RPM file and install scripts, you can copycontent and install on your machine:
with rpm tool: rpm -i
with install script: ./install.sh
Such kind of issues is very troublesome, and it's not so easy to locate them. Could you add the information what MKL version do you use, what is the Linux distribution installed (cat /etc/release*)and what is the machine type you using (uname -a)? Your feedback will be much appreciated and helps us to discover a root cause of problem
- Nikolay
wjiang123
Hello Nikolay,
Thanks for your reply.I will try later what you said here.The following is the information you ask about
MKL version: 10.0.5.025
Machine:
Brand: SGI Altix
Operating system: SuSE Linux Enterprise Server 9.0, 64-bit
Processors: Itanium 2 processors
Compiler: Intel Fortran compiler for linux* versions 9.1
Hope it can make some help.
Wen
