Question about using fgmres
Zhanghong_T_
Hi all,
I am trying to use the fgmres function provided by Intel MKL to solve A*x=b. Since the function provided external matrix-vector operation interface and the input matrix A is not inputted into the functions related to fgmres,I can use it to solve a symmetric matrix and then theinput matrix is lower part.I have the following code:
! FGMRES.f90
! FUNCTIONS:
! FGMRES - Entry point of console application.
! PROGRAM: FGMRES
! PURPOSE: Entry point for the console application.
 program FGMRES
 implicit none
 ! Variables
integer::i,j,n,nr,nz
integer,allocatable::irow(:),jcol(:)
real*8,allocatable::x(:,:),b(:,:),s(:)
nr=1
open(1,file='s.txt')
read(1,*)nz
allocate(irow(nz),jcol(nz),s(nz))
do i=1,nz
read(1,*)irow(i),jcol(i),s(i)
enddo
close(1)
open(1,file='r.txt')
read(1,*)n
allocate(x(n,nr),b(n,nr))
do i=1,n
read(1,*)b(i,1)
x(i,1)=0.d0
enddo
close(1)
call gmressolverd(n,nz,nr,irow,jcol,s,x,b)
! Body of FGMRES
 end program FGMRES
subroutine gmressolverd(n,nz,nr,irow,jcol,s,x,b)
implicit none
integer::ipar(128)
real*8::dpar(128)
integer::i,j,n,nr,nz,irow(1),jcol(1),RCI_request,ntemp,iter
real*8::s(1),x(n,1),b(n,1)
real*8,allocatable::tmp(:)
character(6)::mattype
j=0
do i=1,nz
if(irow(i)>jcol(i))then
if(j==0.or.j==2)j=j+1
elseif(irow(i) if(j==0.or.j==1)j=j+2
endif
if(j==3)exit
enddo
if(j==1)then
mattype='SUNF00'
elseif(j==2)then
mattype='SLNF00'
elseif(j==3)then
mattype='G00F00'
endif
ntemp=150 ! max iterative times
ntemp=((2*ntemp+1)*n+ntemp*ntemp+9)/2+1
ntemp=ntemp+ntemp
allocate(tmp(ntemp))
call dfgmres_init(n, x, b, RCI_request, ipar, dpar, tmp)
if(RCI_request/=0)goto 999
ipar(9)=1
ipar(10)=0
ipar(12)=1
dpar(1)=1.d-20
&nbs p; call dfgmres_check(n, x(:,1), b(:,1), RCI_request, ipar, dpar, tmp)
j=0
do
j=j+1
write(*,*)'iter=',j
call dfgmres(n,x(:,1),b(:,1),RCI_request,ipar,dpar,tmp)
if(RCI_request==0)then
exit
elseif(RCI_request==1)then
call mkl_dcoomv('n',n,n,1.d0,mattype,s,irow,jcol,nz,tmp(ipar(22)),0.d0,tmp(ipar(23)))
cycle
else
goto 999
endif
enddo
call dfgmres_get(n,x(:,1),b(:,1),RCI_request,ipar,dpar,tmp,iter)
return
999 &
write(*,*)'the solver has returned the error code:',RCI_request
call dfgmres_get(n,x,b,RCI_request,ipar,dpar,tmp,iter)
end subroutine
However, the result is not correct. Could anyone point out the errors of my code?
Zhanghong Tang
Intel_C_Intel
Zhanghong,
Did you look at the FGMRES examples that comewith MKL? They may be of help to you. At least that is the intention for developing them and providing them with the library.
Bruce
Zhanghong_T_
Hi Bruce,
Thank you very much for your kindly reply. That code is just from the example, except that I change the matrix-vector product function from 'MKL_DCSRGEMV' to 'mkl_dcoomv', since the input matrix is coordinate format. Could you please help me to locate the problem? I have already attached an input matrix. The 'fgmres' function is a black box for me so I have no idea to check it.
Zhanghong Tang
Zhanghong_T_
Hi Bruce,
Thank you very much! I have found the problem and the code can run well now.
Zhanghong Tang
Intel_C_Intel
Glad to hear that things are running correctly for you now. Wish I could say that I had been a major help here, but in honesty I can't smiley [:-)].
Bruce
Zhanghong_T_
Hi Bruce and all,
Thanks for your kindly reply!
Another question: It seems that the dynamical allocated array'tmp' is associated with maximal iteration times given by ipar(15) (default value is 150). However, for very large martrix size, the solution can't be converged even witha preconditioner after maximal iteration times. Furthermore, we wish to decrease the size of allocated array 'tmp' to save memory (so the value of ipar(15) will be modified). Basing on these considers, we need to 'restart' the GMRES, which is the great feature of FGMRES.
Could any one tell me how to 'restart' the GMRES based on the example code?
Zhanghong Tang
