Question using vdmul
Ferriere__Axelle
On my MAC with Intel, using vdmul does not make the multiplication of two matrices faster than the usual A*B multiplication.
Is this normal? Or does it mean that maybe I did not install MKL properly?
Thank you very much in advance for your help
Zhen_Z_Intel
Dear customer,
The performance depends on the size of your calculating vectors and parallelization of your program and even your system workaround(CPU, OS, compiler...)Could you please provide more information and a test sample to show how you implement and how you compared with. So that I could help you to have a check. Thanks.
Fiona
Ferriere__Axelle
Dear Fiona, thank you for your answer.
The code I'm implementing is the following:
program MAIN
    implicit none
    integer, parameter :: Na = 250, Nx = 100, NS = Na*Nx
    integer            :: rA, cA, rB, cB, icA, icB, ic
    real(8) 		:: t_in, t_out
    real(8)            :: A(NS,Na), B(NS,Nx), KK(NS,NS)
    A = 1.0D0
    B = 2.0D0
    rA = size(A,1)
    cA = size(A,2)
    rB = size(B,1)
    cB = size(B,2)
    KK = 0.0D0
    call cpu_time(t_in)
    do icA = 1, cA
        do icB = 1, cB
            ic = (icA - 1)*cB + icB
            KK(:,ic) = A(:,icA)*B(:,icB)
        end do
    end do
    call cpu_time(t_out)
    print *, '("Computing KK without vdmul takes = ",f2.6," seconds.")', t_out - t_in
   call cpu_time(t_in)
   do icA = 1, cA
        do icB = 1, cB
            call vdmul( rA, A(:,icA), B(:,icB), KK(:,ic) )
        end do
    end do
    print *, '("Computing KK with vdmul takes = ",f2.6," seconds.")', t_out - t_in
end program MAIN
The output I'm getting is as follows:
 ("Computing KK without vdmul takes = ",f2.6," seconds.")   1.02616200000000
 ("Computing KK with vdmul takes = ",f2.6," seconds.")      1.16865000000000
I have tried varied sizes for Na and Nx: usually there is no significant difference using vdmul; if at all, it's slowlier in the latter case. The only thing that makes a significant difference for the speed of the code is whether the following line is commented or not:
    KK = 0.0D0
I'm using OS X 10.11.6. Thank you for your help, and best regards,
Axelle
TimP
Auto vectorization of your source code ought to achieve full performance. If there is further performance to be gained by threading, it may be done better outside the inner loop. Anyway threading would at best reduce elapsed but not cpu time so if vdmul does that you may want system_clock
Ferriere__Axelle
Dear Tim,
I see, thanks a lot for your quick reply!
Best,
Axelle
