C# dtrnlspbc_init
Gianluca_G_1
I'm trying to understand how to declare and use in C#: RCI TR Routines for Problem with Bound Constraints.
I have created a simple test console program, and declared just one function (dtrnlspbc_init) but  I receive that "there was an error in the input parameters".
It is a Marshalling problem, I suppose, but I don't understand where there is the error.
Is there someone that can help me?
Thankyou
Gianluca
mecej4
Check the second and third arguments to dtrnlspbc_init(). I believe that you have them interchanged.
Gianluca_G_1
Now it works! thank you
by the way the documentations it is not so clear.
Best Regards
Gianluca
mecej4
Which version of the documentation do you mean? The current MKL documentation at https://software.intel.com/en-us/node/471100#867C84A5-D029-4C48-B63B-B68E04CE043D clearly states that the second and third arguments are the number of variables and number of functions whose sum of squares is to be minimized.
Ying_H_Intel
Hi Thank you a lot for the reply mecej4.
Hi Gianluca,
You can take the second and third arguments are x length  and F(x) length (or   m - dimension of function value */.)
actually,  the solver required m>>n.Where  n is  array X's size;  m is  fvec Array of size m.  So you may be change the m = xxx. when go to solve step based on your fvec.
Ying
Gianluca_G_1
If I read this page https://software.intel.com/en-us/node/471100#867C84A5-D029-4C48-B63B-B68E04CE043D,
n is the number of variables and, m is the number of functions. In my case I have n=5 and m=1 but this is not allowed because m >> n.
Maybe the parameter are swapped in the dtrnlspbc_init().
Best Regards
Gianluca
mecej4
In that case, you are attempting to obtain five unknowns from a single scalar observation, i.e., you have a standard bound-constrained minimization problem -- instead of the kind of problem that ?TRNLSBC is designed to solve -- a least-squares minimization of an overdetermined problem. For your class of problems, you should use a solver such as those listed for that class in http://plato.asu.edu/sub/nlores.html and http://plato.asu.edu/sub/nlounres.html .
Gianluca_G_1
Thank you for your suggestions.
now it is more clear to me, by the way, I've implemented a test code like the example in the web page (https://software.intel.com/en-us/node/522321).
The objective_function is my_function().
The loop exited correctly but I can't understand where to find the solution!
check row code number 411.
What I miss?
Thank you very much
Gianluca
mecej4
The solution is in xres[], since you used Marshall.Copy to put it there. All that you have to do is to add a formatted output statement such as
     Console.WriteLine(string.Format("{0:0.00} {1:0.00} {2:0.00} {3:0.00} {4:0.00}",
                  xres[0],xres[1],xres[2],xres[3],xres[4]));
Gianluca_G_1
I'm sorry, maybe I was not clear ...
Do you really thought that after the Marshal.Copy(), I couldn't get the array values?
The problem is that the result it is not right!
I mean, these are the initial values. The solutions should be differents.
These should be the correct results:
0 = 197
1 = 351
2 = 185
3 = 1,7
4 = 8,8
We are sure of this, because we got it with another algoritms (Amoeba)
Thank you
Gianluca
Gianluca_G_1
mecej4 i got the solution!
now it works ....
I forgot to copy the result with Marshal.Copy  in my_function proc.
public static void my_function(ref int m, ref int n, [In] IntPtr xp, [Out] IntPtr fp)
            double[] x = new double;
            Marshal.Copy(xp, x, 0, n);
            double[] f = new double;
            Marshal.Copy(fp, f, 0, m);
            double rho1 = x[0];
            double rho2 = x[1];
            double rho3 = x[2];
            double h1 = x[3];
            double h2 = x[4];
            //double phi = 0;
            //int iN = m; // mlMeasures.Count; //Da inserire
            for (int i = 0; i < m; i++)
                f = Math.Pow((mlMeasures.RhoM - RhoCalc(mlMeasures.A, rho1, rho2, rho3, h1, h2)) / mlMeasures.RhoM, 2);
            Marshal.Copy(f, 0, fp, m);
Thank you very much
Gianluca
