7297 Discussions
Request for Guidance on mkl_rt.dll Usage in Intel oneAPI MKL (2025.3.2.20)
rohmijeong
I am currently using Intel oneAPI Base Toolkit version 2025.3.2.20 (offline installer), and I would like to request clarification regarding the usage of the MKL runtime library.
After installation, I observed the following:
  • The file  %MKLROOT%\lib\mkl_rt.lib exists.
  • However, %MKLROOT%\bin\mkl_rt.dll is not present.
  • Instead, only %MKLROOT%\bin\mkl_rt.2.dll is available.
Based on this situation, I was advised to create an alias using the following command:
mklink "%MKLROOT%\bin\mkl_rt.dll" "%MKLROOT%\bin\mkl_rt.2.dll"
Before proceeding, I would like to confirm whether this approach is officially supported and recommended.
Specifically, I would appreciate guidance on the following points:
  1. Is mkl_rt.2.dll intended to replace mkl_rt.dll in recent oneAPI versions?
  2. Is creating a symbolic link (alias) to mkl_rt.dll a correct and stable solution for build and runtime compatibility?
  3. Are there any recommended alternatives for ensuring compatibility with build systems that expect mkl_rt.dll?
  4. Is there an official method to install or enable mkl_rt.dll, or has it been deprecated?
My use case involves building Python C-extensions and numerical libraries (e.g., NumPy) that rely on mkl_rt linkage.
I would appreciate any official documentation or recommendations regarding this configuration.
Thank you for your assistance.
MiJeong Roh
Fengrui
oneMKL started to add shared library versioning from 2021.
Do you need to load mkl_rt.x.dll directly at run time or use mkl_rt.lib (and then load mkl_rt.x.dll at run time)?
Best,
Fengrui
rohmijeong
Thank you for your response.
In my case, I expected the application to load MKL correctly after building with "mkl_rt.lib". However, at runtime, I encountered an import error.
While investigating the cause of the runtime loading failure, I found that:
- "%MKLROOT%\lib\mkl_rt.lib" exists
- "%MKLROOT%\bin\mkl_rt.dll" does not exist
- "%MKLROOT%\bin\mkl_rt.2.dll" exists
To work around the issue, I created a symbolic link:
After applying this symbolic link, the runtime loading issue was resolved.
Could you please clarify the following points?
1. In recent oneMKL versions, is it expected that "mkl_rt.dll" is no longer included and only "mkl_rt.2.dll" is provided?
2. Is creating a symbolic link from "mkl_rt.dll" to "mkl_rt.2.dll" an officially supported and safe workaround?
3. If using "mkl_rt.lib" during build, what is the recommended runtime configuration to ensure that "mkl_rt.2.dll" is loaded correctly without requiring "mkl_rt.dll"?
4. Is there any official alternative for compatibility with Python extensions or build systems that still expect "mkl_rt.dll" at runtime?
MiJeong Roh
Fengrui
When building with mkl_rt.lib, it will look for the corresponding mkl_rt.x.dll at run time. For example, in 2025.3, it looks for mkl_rt.2.dll, while in 2026.0, it looks for mkl_rt.3.dll. You can check in your installation by dumpbin /headers mkl_rt.lib | findstr /i "\.dll"So if you see errors asking for mkl_rt.dll, it indicates that the binary was built with old mkl_rt.lib. You need to build the binary again with the current mkl_rt.lib.
For your questions,
  1. Yes. In the latest 2026.0 release, it is mkl_rt.3.dll.
  2. It is not officially supported.
  3. To use "mkl_rt.lib" in the same oneMKL release as "mkl_rt.2.dll". It should not require mkl_rt.dll.
  4. The expected mkl_rt.x.dll at run time depends on the oneMKL version it used at build time. If it was built with a relatively new oneMKL release, for example, 2026.0, it should expect "mkl_rt.3.dll" rather than mkl_rt.dll.
Best,
Fengrui
