7303 Discussions
Run pasrdisosolver. CPP to call pardisoinit(pt, &mtype, iparm); Throws an exception after a function
MRSPai
the error is:0x00000001801151D8 (libpardiso600-WIN-X86-64.dll)处(位于 Surface_Mesh.exe 中)引发的异常: 0xC0000005: 写入位置 0x00007FF92CCD098D 时发生访问冲突。
void PardisoSolver::pardiso_init()
mtype = -2;
max_fct = 1;
mnum = 1;
msglvl = 0;
error = 0;
if (mtype == -1)
throw std::runtime_error("Pardiso mtype not set.");
for (i = 0; i < 64; i++)
pt[i] = 0;
result.clear();
result.resize(num, 0);
nrhs = 1;
error = 0;
solver = 0;/* use sparse direct solver */
for (i = 0; i < num + 1; i++) {   //This is where the exception is flagged
ia[i] += 1;
for (i = 0; i < nnz; i++) {
ja[i] += 1;
phase = 11;
pardiso(pt, &max_fct, &mnum, &mtype, &phase,
&num, a.data(), ia.data(), ja.data(), &idum, &nrhs,
iparm, &msglvl, &ddum, &ddum, &error);
//And when I comment out the first one, it's going to report an error here again
if (error != 0) {
printf("\nERROR during symbolic factorization: %d", error);
exit(1);
I don't know if it's mKL_pardiso.h or something else, is it related to the MKL version? My version is compilers_and_libraries_2017.1.143
mecej4
You appear to be mixing calls to the Pardiso routines in MKL with calls to the Basel-Lugano version of Pardiso (www.pardiso-project.org). Although the two versions have common origins, they are not mutually interchangeable.
MRSPai
Maybe you're right, but the pardisoSolver.h
#include <vector>
#include <cmath>
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <iostream>
#include "mkl_pardiso.h"
#include "mkl_types.h"
#include"mkl.h"
Need mkl_pardiso.h.I don't know where to find this header except Intel MKL
mecej4
I concluded that you used the Basel-Lugano Pardiso since the reported error message refers to libpardiso600-WIN-X86-64.dll. That DLL is definitely not part of MKL.
MKL comes with several examples of calling MKL-Pardiso from C and Fortran. The MKL documentation of calls to MKL routines indicates which MKL header files are associated with each MKL routine, including pardisoinit() and pardiso().
MRSPai
I see what you mean. Thank you very much. I'll give it a try
MRSPai
I tried as hard as I could, and that's exactly what you said, but if I delete the libpardiso600-WIN-X86-64.dll, the program will report a missing error, but if it's there, I can't fix it. How do I make it exist in the project but not call it in the function?Is there any way you can tell me?
mecej4
Please make up your mind as to whether you wish to use either the MKL version or the Basel-Lugano version of Pardiso. Once you select one of the two, build and run your program using that version, and only that version. The details of how to do build and run depend on whether you use the command line or Visual Studio, but the basic rules are straightforward.
In short, for each external routine that your program calls, there should be only one library that provides that routine.
