Runtime link problem with MacOSX and g++
leucetios
I have MKL 10.0.3, IPP5.3.3and gcc 4.0.1 running on darwin 8.11.1.
I am dynamically linking the following files: mkl_sequentialmkl_core mkl_intel
I do not get an link failures, however, at run time the program exits with code 1. Using ktrace I can determine that it finds all necessary dylibs.
If anyone has some suggestions or information that may help it would be appreciated, thanks in advance.
Ying_H_Intel
Might be some mistake in other place. Could you send us your code and compile command so we can reproducethen investigate the problem?
Ying
