hpcc + mkl/fftw linking error
sonicato
I get two undefined reference while linking the hpcc benchmark with the mkl 10.0.5 and the new beta release, which was delivered with 11.0.044 Compiler Suite:
/opt/intel/Compiler/11.0/044/mkl/lib/em64t/libmkl_intel_lp64.a(_DftiFreeDescriptorDM_lp64.o): In function `dftifreedescriptordm_':
_DftiFreeDescriptorDM_iface.c:(.text+0x2): undefined reference to `mkl_cdft_DftiFreeDescriptorDM'
/opt/intel/Compiler/11.0/044/mkl/lib/em64t/libmkl_intel_lp64.a(_DftiCommitDescriptorDM_lp64.o): In function `dfticommitdescriptordm_':
_DftiCommitDescriptorDM_iface.c:(.text+0x2): undefined reference to `mkl_cdft_DftiCommitDescriptorDM'
My linker flags:
-L/opt/intel/Compiler/11.0/044/mkl/lib/em64t /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libfftw2xc_intel.a /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libfftw2xf_intel.a /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libfftw2x_cdft_DOUBLE.a -lmkl_cdft_core -lmkl_blacs_openmpi_lp64 -lmkl_em64t -lguide -lmpi -lm
I compiled the hpcc with the -DUSING_FFTW, also complied the fftw2c wrapper and mpi mkl fftw library.
Any help would be appreciated.
Thanks in advance,
Jens
Andrey_G_Intel2
Quoting - sonicato
My linker flags:
Thanks in advance,
Jens
sonicato,
the linker in Linux-like OSes is sequential dependent. Try to change your link line to "L/opt/intel/Compiler/11.0/044/mkl/lib/em64t /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libfftw2xc_intel.a /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libfftw2xf_intel.a /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libfftw2x_cdft_DOUBLE.a -Wl,--start-group -lmkl_blacs_openmpi_lp64 -lmkl_em64t -lmkl_cdft_core -Wl,--end-group -lguide -lmpi -lm"
Andrey
Vladimir_Petrov__Int
New Contributor III
Quoting - sonicato
My linker flags:
Thanks in advance,
Jens
Hello Jens,
What you need to do is to change the linker flags as follows:
-L/opt/intel/Compiler/11.0/044/mkl/lib/em64t /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libfftw2xc_intel.a /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libfftw2xf_intel.a /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libfftw2x_cdft_DOUBLE.a -Wl,--start-group /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libmkl_cdft_core.a /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libmkl_intel_lp64.a /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libmkl_intel_thread.a /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libmkl_core.a /opt/intel/Compiler/11.0/044/mkl/lib/em64t/libmkl_blacs_openmpi_lp64.a -Wl,--end-group -lguide -lmpi -lm
This should resolve the dependency.
By the way, keep in mind that HPCC uses MPI FFTW interface in a modified manner. Namely the following functions must be altered to work with 64-bit integers (e.g. size_t instead of int's): fftw_mpi_create_plan and fftw_mpi_local_sizes.
-Vladimir
sonicato
Thx for the fast answers!
These two replies solved my problem.
Jens
