SPARSE BLAS CSR FORMAT
Aaron_M_
There seems to be no consistency with the CSR format in mkl. Using the function "mkl_ddnscsr", I convert a matrix, A, to csr format. It works great, because I put that into "dfeast_scsrev" and have no problems. But when I want to use "mkl_dcsrmm" what the hell are pointers b and e? I've uploaded my code and was hoping someone could take a look. Is there a function that converts dense matrices into csr format for sparse BLAS?
Aaron.
Noah_C_Intel
Hello, I will research what is happening and some best known methods for what you are trying to do.
Aaron_M_
Noah,
Thank you for the help. I'll be anxiously waiting, let me know!
Aaron.
Noah_C_Intel
In your example matrices B and C were print transposed. I’ve implemented 2 different example with modification to represent in the correct way (in Fortran style/example-2) and case when we decided numbering elements of B and C during row (C style/example).
Aaron_M_
Noah,
Thanks for the help. Did you just change "matdescra[3] = F" to "matdescra[3]=C"? I don't see anyother changes.
Aaron.
Noah_C_Intel
Don't forget job[2] = 1; //change to 0; in mkl_ddnscsr(job,&n,&n,A,&n,Acsr,AJ,AI,&info);
