SVD inside c#
darkcminor
I am doing a class for using svd inside c#, I have searched and think the svd function is dgesvd
I am doing something like this, but I do not know if the names are correct, Could you please tell me How to put the correct call and the parameters, thanks in advance
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Security;
using System.Runtime.InteropServices;
using mkl;
namespace csmkl
class Program
static void Main(string[] args)
Int32 n = 3, m = 3;
Int32 lda = n, ldu = m, ldvt = n;
Double[] superb = new Double[m - 1];
Double[] s = new Double;
Double[] u = new Double[n * n];
Double[] vt = new Double[n * n];
Double[] A = new Double[9]
8.79, 9.93, 9.83,
6.11, 6.91, 5.04,
-9.15, -7.93, 4.86
Char a1 = 'A';
Char a2 = 'N';
int mat_order = 0;
MKLImports.LAPACKE_dgesvd(
ref mat_order,
ref a1,
ref a2,
ref m,
ref n,
A,
ref lda,
s,
u,
ref ldu,
vt,
ref ldvt,
ref superb);
Console.WriteLine("s[0]: " + s[0]);
namespace mkl
[SuppressUnmanagedCodeSecurity]
internal sealed class MKLImports
private MKLImports()
[DllImport("mkl_rt.dll", ExactSpelling = true, SetLastError = false, CallingConvention = CallingConvention.Cdecl)]
internal static extern voidLAPACKE_dgesvd(
ref int matrix_order,
ref char a1,
ref char a2,
ref int m,
ref int n,
[In, Out] double[] input_matrix,
ref int lda,
[In, Out] double[] s,
[In, Out] double[] u,
ref int ldu,
[In, Out] double[] vt,
ref int ldvt,
ref double[] superb
Ying_H_Intel
Hello darkcminor,
As MKL blas (Cblas)and lapack (lapacke)support both fortran and C interface.The LAPACKE is C interface, so the ref pass is not needed. you may change the code either to use c interface as below or use dgesvd fortran interface as Using Intel Mkl In Your C# Program
Ying
using System;
using System.Text;
using mkl;
namespace csmkl
class Program
Int32 n = 3, m = 3;
8.79, 9.93, 9.83,
6.11, 6.91, 5.04,
-9.15, -7.93, 4.86
Char a1 = 'A';
Char a2 = 'N';
int mat_order = 101;
Int32 info = 0;
double[] work1 = new double[1];
double[] work;
int lwork = -1;
mat_order,
a1,
a2,
m,
n,
A,
lda,
s,
u,
ldu,
vt,
ldvt,
superb);
/* MKLImports.dgesvd(
ref a1,
ref a2,
ref m,
ref n,
A,
ref lda,
s,
u,
ref ldu,
vt,
ref ldvt,
work1,
ref lwork,
ref info);
Console.WriteLine("info on exit: " + info);
Console.WriteLine("work1[0]: " + work1[0]);
lwork = (int)work1[0];
work = new double[lwork];
MKLImports.dgesvd(
ref a1,
ref a2,
ref m,
ref n,
A,
ref lda,
s,
u,
ref ldu,
vt,
ref ldvt,
work,
ref lwork,
ref info);
namespace mkl
internal static extern void LAPACKE_dgesvd(
int matrix_order,
char a1,
char a2,
int m,
int n,
int lda,
int ldu,
int ldvt,
double[] superb
/* internal static extern void dgesvd(
ref char a1,
ref char a2,
ref int m,
ref int n,
ref int lda,
ref int ldu,
ref int ldvt,
[In, Out] double[] work,
ref int lwork,
ref int info
Ying_H_Intel
Hello darkcminor,
Ying
using System;
using System.Text;
using mkl;
namespace csmkl
class Program
Int32 n = 3, m = 3;
8.79, 9.93, 9.83,
6.11, 6.91, 5.04,
-9.15, -7.93, 4.86
Char a1 = 'A';
Char a2 = 'N';
Int32 info = 0;
double[] work;
int lwork = -1;
mat_order,
a1,
a2,
m,
n,
A,
lda,
s,
u,
ldu,
vt,
ldvt,
superb);
ref a1,
ref a2,
ref m,
ref n,
A,
ref lda,
s,
u,
ref ldu,
vt,
ref ldvt,
work1,
ref lwork,
ref info);
MKLImports.dgesvd(
ref a1,
ref a2,
ref m,
ref n,
A,
ref lda,
s,
u,
ref ldu,
vt,
ref ldvt,
work,
ref lwork,
ref info);
namespace mkl
int matrix_order,
char a1,
char a2,
int m,
int n,
int lda,
int ldu,
int ldvt,
double[] superb
ref char a1,
ref char a2,
ref int m,
ref int n,
ref int lda,
ref int ldu,
ref int ldvt,
ref int lwork,
ref int info
darkcminor
Thanks this is working, I would like to ask something more
I have found this page where you can see what libraries are recommended for a particular use case, specify the parameters in the drop down lists
If I Got
mkl_intel_c_dll.lib mkl_intel_thread_dll.lib mkl_core_dll.lib /Qopenmp
Where do I include this in Parrallel Studio XE 2011 with Visual Studio 2008?...
Does mkl_intel_thread_dll.lib assures multithreading?
Ying_H_Intel
Right, mkl_intel_thread_dll.lib is multithreading layer library. and *_dll, means dynamic link.
Here is more informationabout the topic.
http://software.intel.com/en-us/articles/parallelism-in-the-intel-math-kernel-library/
and http://software.intel.com/en-us/articles/intel-math-kernel-library-intel-mkl-for-linux-linking-applications-with-intel-mkl-version-100/
Ying
