7303 Discussions
Scalability of dense symmetric indefinite factorization
Rehfeldt__Daniel
I am trying to speed up the factorization of a dense symmetric indefinite matrix, the size of my matrices is usually between 10 k and 20 k.
I am using LAPACK (dsytrf) and MKL 2018 and I run it on a supercomputer node with two Intel Xeon E5-2680 v3 Haswell CPUs (2 x 12 Cores, 2,5 GHz). I also tried a node with  Intel Xeon Phi 7250-F Knights Landing  CPU and 68 cores, 1.4 GHz. The problem is that the factorization does not seem to scale very well with the number of threads I use: with up to 8 threads I see some improvement (the run time is halfed) but after that there is even a slowdown.
Is this something that is to be expected from this MKL routine? And if so, do you know of any alternative that scales better?
Daniel
Ying_H_Intel
Hi Daniel, Do you mean on both machine, the thread scale is limited to thread 8? it is not expected. we publish some factorization benchmark like dgetrf https://software.intel.com/en-us/mkl/features/benchmarks on xeon and xeon phi. for your reference. And if need, please submit the exact issue to https://supporttickets.intel.com/?lang=en-US with your reproduce matrix. Best Regards, Ying
Rehfeldt__Daniel
Hi Ying,
thanks for your help. On both machines the factorization does not scale beyond 8 threads.I will submit the matrix to the support, as you suggested.
Best
Daniel
Denis_S_Intel
Hi Daniel,
We have been working on improving this functionality in terms of performance and scalability, the optimizations will be available in one of the next releases.
Rehfeldt__Daniel
Hi Denis,
thanks for the information. Do you have an idea on how long this will take (several months, a year, etc)? I am not familiar with your release cycles. Would you recommend to try an LU factorization until then? According to your benchmarks that seem to scale beyond 8 threads.
Denis_S_Intel
Hi Daniel,
The new release is expected this month. As for LU factorization, yes I think it's a good way to try LU instead of LDLT until the new release is available.
May I ask you what are you going to do with the results once you have them?
Rehfeldt__Daniel
Hi Denis,
thanks again. Will your enhancements be in the release notes? Otherwise could you let me know once it has been released?
I will try the LU factorization then. Would you expect it to scale to 68 Cores (lets say for a 10 k matrix)?
I use the factorization for solving two to four linear systems with different right hand sides.
Denis_S_Intel
Hi Daniel,
Yes, the enhancements will be in the release notes and yes, the LU factorization shows good scalability.
