Segfault when using cblas_dgemm()
Sesto__Dominic
When attempting to use the cblas_dgemm() function, I am experiencing a segmentation fault. The segfault occurs only when running the code on a Linux machine (works on a Windows machine).
The code is set up as follows:
#define ML_ROWS_A 5
#define ML_COLS_B 7
#define ML_COLS_A 6
double a_d[ML_ROWS_A*ML_COLS_A], b_d[ML_COLS_A*ML_COLS_B], c_d[ML_ROWS_A*ML_COLS_B];
const double  alpha = 1.0;
const double  beta  = 1.0;
int m = ML_ROWS_A;
int n = ML_COLS_B;
int k = ML_COLS_A;
cblas_dgemm( CblasRowMajor, CblasNoTrans, CblasNoTrans, m, n, k, alpha, a_d, k, b_d, n, beta, c_d, n );
If I add the calls:
int n_alloc;
mkl_mem_stat(&n_alloc);
Before calling cblas_dgemm(), the function works correctly (though no memory has been allocated through mkl calls). Similarly, if I instead allocate memory through an mkl call (such as mkl_calloc) before calling cblass_dgemm() the function works correctly (even though I do not actually pass the allocated memory to the function call). Can anyone explain why the segfault is occurring and why calling certain mkl functions before cblass_dgemm remedies the issue?
Ying_H_Intel
Hi Sesto,
do you have a small code for the problem?   from the code,
int m = ML_ROWS_A;
int n = ML_COLS_B;
int n = ML_COLS_A;
​Seem you haven't lda =K defined and "n" was written two times?
​Best Regards,
​Ying
Sesto__Dominic
Ying H,
That was just a typo when posting the question. I edited the original post to reflect this.
Thank You,
Dominic
Khang_N_Intel
Hi Dominic,
We are investigating this issue.  It would be helpful if you can send us a sample code, not just a code snippet, so that we can recreate the issue?
Thank you,
Khang
Khang_N_Intel
Hi Dominic,
The code snippet you provided didn't give any error.
As I have mentioned in the previous post, can you send us your entire code where you saw the error?
Khang
Khang_N_Intel
Hi Dominic,
I forgot to mention that the dimensions you provided are too small to cause any seg fault.
Khang
Sesto__Dominic
Attached is an Eclipse project that demonstrates the segfault occurring when run on Linux 6.6. The call to cblas_dgemm functions correctly if it is the only test called. The call to cblas_sgemm also works correctly if it is the only test called. If the test that calls cblas_sgemm is called before cblas_dgemm, a segfault occurs.
Eclipse Details:
Eclipse IDE for C/C++ Developers
Version: Oxygen.3 Release (4.7.3)
Gennady_F_Intel
I extracted the *. and cpp code and checked how this works on my local RH7 system with latest available version of mkl - 2018.3
AVX based system:
icc -mkl -DINTEL_MKL_MATH MatrixMulTest.cpp
./a.out
MKL_VERBOSE Intel(R) MKL 2018.0 Update 3 Product build 20180406 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions (Intel(R) AVX) enabled processors, Lnx 2.80GHz lp64 intel_thread
MKL_VERBOSE SGEMM(N,N,7,5,6,0x7ffd0e2ffc28,0x6412c0,7,0x641240,6,0x7ffd0e2ffc30,0x641380,7) 144.96ms CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:20
testFloatMatrixMul passed
MKL_VERBOSE DGEMM(N,N,7,5,6,0x7ffd0e2ffc10,0x6415c0,7,0x6414c0,6,0x7ffd0e2ffc18,0x641720,7) 33.26us CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:20
testDoubleMatrixMul passed
uname -a:
Linux iris 3.10.0-693.17.1.el7.x86_64 #1 SMP Sun Jan 14 10:36:03 EST 2018 x86_64 x86_64 x86_64 GNU/Linux
AVX-512 ( code name - SkyLake  - Intel(R) Xeon(R) Platinum 8168 CPU @ 2.70GHz ) :
$ ./a.out
MKL_VERBOSE Intel(R) MKL 2018.0 Update 3 Product build 20180406 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) enabled processors, Lnx 2.70GHz lp64 intel_thread
MKL_VERBOSE SGEMM(N,N,7,5,6,0x7ffc843cea28,0x6412c0,7,0x641240,6,0x7ffc843cea30,0x641380,7) 151.81ms CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:48
MKL_VERBOSE DGEMM(N,N,7,5,6,0x7ffc843cea10,0x6415c0,7,0x6414c0,6,0x7ffc843cea18,0x641720,7) 19.52ms CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:48
Sesto__Dominic
We built with GNU, not ICC. Additionally we are using the 2017 version of MKL, not the 2018 version.
Thank You
Gennady_F_Intel
i don't expect building by icc or gcc will affect, but i will check this later and let you know
Sesto__Dominic
Some additional environment information:
Compiler: gcc 4.8.5
OS: CentOS Linux v7.4
We used the 2017 version of the MKL Library
Gennady_F_Intel
we recommend you to evaluate the latest mkl 2018.3 ( take this binaries from this site - https://software.intel.com/en-us/performance-libraries ) and check if the problem is still exists with this update too.
