7234 Discussions
Segmentation fault using dotc() and dotu(), MKL 8.1.1 on MacOSX 10.4.7
huil
Did anyone encounter this problem. The following code causes Segmentation fault (or Bus error in some other similar codes). I've submitted an issue about this.
struct cpl
double r;
double i;
extern "C"
cpl zdotc_ (int *N, cpl *X, int *IncX, cpl *Y, int *IncY);
int main ()
cpl c; c.r = c.i = 1;
cpl a[1] = {c}, b[1] = {c};
int i = 1; int n = 3;
cpl res = zdotc_(&n,a,&i,b,&i);
return 0;
TimP
On linux, I don't get that failure. It does look as if you are forcing zdotc_() to read beyond the end of your declared a[] and b[].
Intel_C_Intel
Thanks fo replying. That's a typo in my posted code, when I was simplifying it.
But the runtime error still exists even that's corrected, something like "Illegal instruction".
Intel_C_Intel
I solved the problem. It was caused by incorrect using of Fortran functions returing a complex value, I found the following link: http://www.intel.com/support/performancetools/libraries/mkl/sb/cs-017175.htm#3
