Small matrix speed optimization
marko_m_
Hello all,
since I can run now the mkl library 2017, I have a couple of follow up questions that hopefully deserve a thread of their own. I am doing some mode matching, and consequently I need matrix inversions on matrices of the order 10x10 up to 50x50 most of the time (the maximum size would be somewhere aroud 200x200 but very rarely, they will almost exclusively be in the 10-50 range). I have optimized my non mkl parts of the code so they are under 10% of all the simulation time, so any speedup on the mkl functions would be greatly beneficial, if possible. Now I have set the mkl_num_threads to max, release mode, ia32, O2 optimization, optimized for speed and so forth to make it as fast as I can/know to make currently. I only have a couple of matrices to invert per frequency point (5 to 6), and the code must execute one frequency point at a time. My questions are as follows:
1) Is there a way to improve  the performance of the mkl functions in any way (by setting some flags in the program itself, or in Visual studio, or am I missing some functions that are better in this situation, or something else completely), either in the mkl 2017 or the old mkl 10.0.012 that I have? I am using cblas_zgemm, cblas_zdscal, zgetri, zgetrf, vzSqrt, cblas_zaxpy, but most of the time is spent in matrix inversion, so zgetri, zgetrf take most of the time. Are there better functions than these or can I set some additional flags to make them faster?
2) Since the optimization is for speed and not size, I of course expected the output (exe) to be bigger, but can someone explain and/or help me optimize the output size for the exe in mkl 2017, because it is 3x bigger than with the old mkl 10.0.012? This represents a small problem unfortunatelly, and if possible I would be very happy if it can be mittigated in any way (without optimize for size)
3) Some of the matrices are symmetrical, and I was hopping that the symmetrical versions of zgetri, zgetrf, that is zsytrf and zsytri, I would be able to theoretically get a 2x speedup, but for some reason the speed is the same. Is this expected? Are my matrices too small for any noticeable effect? Am I missing something? In both cases I feed the functions the full matrix to invert, and while I am debugging I can see that only half of the matrix elements are calculated for the symmetrical functions, and I fill the symmetric elements, but there is no speed up.
Any information, even if not good is welcome. Thank you all in advance.
Ying_H_Intel
Hi Marko,
It is nice topic for discuss here.   If possible, could you attach your test code, especially zgetri, zgetrf code, so we can test at same basic line?
Some comments about your questions
1. the matrix size 10x10 to 50x50. (max 200x200).  right, the matrix size seem too small to optimize by any ways.
But as you tried,  Here  is some tips to improve the performance or reduce overhead of MKL way ,
1.1 may you please  try -DMKL_DIRECT_CALL_SEQ
https://software.intel.com/en-us/articles/improve-intel-mkl-performance-for-small-problems-the-use-of-mkl-direct-call
https://software.intel.com/en-us/mkl-linux-developer-guide-limitations-of-the-direct-call
1. 2. what kind of CPU are you using?  try sequential MKL or set OMP_NUM_THREADS=1,2, 4 etc  and find the best performance. (as for small workload, it may not best solution to set max threads.
1.3 other tips, like array alignments etc.  https://software.intel.com/en-us/mkl-linux-developer-guide-other-tips-and-techniques-to-improve-performance
2. Regarding the exe size. How do you link mkl in your code?  Maybe the later version add more CPU-specific optimized code thus bigger size.  You may read the article   https://software.intel.com/en-us/articles/intel-math-kernel-library-intel-mkl-linkage-and-distribution-quick-reference-guide  and find some suitable link model.
3. the symmetric feature may or may not helps. The problem may be caused by small matrix or less optimize in MKL functions. Let's test if you provide the test code.
Best Regards
Ying
marko_m_
Hi Ying,
Thanks for all the suggestions. It is more out of curiosity, since there is a big difference between the mkl versions I am using. Essentially there is no noticeable difference in speed for me between mkl 10.0.012 and mkl 2017, but I was hoping that with potential new options there could be some new options that I don't know or have overlooked. As for the suggestions I have tried:
1.1 When I add the MKL_DIRECT_CALL_SEQ or MKL_DIRECT_CALL to the preprocessor I get some errors of the form "cannot convert argument k from complex<double> * to const MKL_Complex16 *". I have used some variables of complex double form as arguments for mkl functions but before using this preprocessor directive I did not get these errors, and the produced results were correct.
1.2 My CPU is Intel Core i7-2670 QM @ 2.20 GHz. I have tried testing with different number of threads, but the max number always gave the smallest time, but only by a little bit, maybe there was a 15% difference between 1 thread and 4 threads, and 2 and  4 are almost the same.
1.3 I have not tried this, but will try to see if it helps.
2. It is static linking, but I only used the automatic inclusion  of mkl in Visual studio. I will try individual libraries, like in the old mkl version to see if I can reduce the size of the exe.
My example code is bellow. The first function is to check if the matrix is symmetric, checks separately the real and imag part to a given tolerance, and the other function uses the first one to determine the input matrix symmetry and if symmetric uses the symmetric mkl functions.The third function is for matrix multiplication, two matrices in, one out, nothing special. There could be errors in my code, or total misunderstanding of what the functions should do, so if anybody has any complaints, feel free to express them. I did the visual studio profiler and diagnostics on my release version and 77.2% of the time is in libiomp5md.dll (I don't know if this can be optimized), and from the other 22.8%, about 16% is in zgemm, zgetrf and zgetri (for a 40x40 matrix test). This was done for 1000 frequency points, so to have some reasonable time measurement, so 77.2% and the other values are after 1000 calls to my top level function. In the matrix multiply function, there are const complex<double> alpha (1.0,0.0), beta(0.0,0.0).
If I missed anything please ask, and thank you all in advance for the advices.
Matrices are made with :  new MKL_Complex16[N*N], so maybe the alignment would do something.
bool m_check_if_matrix_symmetric(MKL_Complex16 * matrix, int N){
	bool result = true, test_real_part, test_imag_part;
	int i, j;
	double num_real_1, num_real_2, eps = 1e-10;
	for (i = 0; i < N; i++){
		for (j = i+1; j < N; j++){
			num_real_1 = matrix[i*N + j].real;
			num_real_2 = matrix[j*N + i].real;
			test_real_part = fabs(num_real_1 - num_real_2) <= ((fabs(num_real_1) < fabs(num_real_2) ? fabs(num_real_2) : fabs(num_real_1)) * eps);
			num_real_1 = matrix[i*N + j].imag;
			num_real_2 = matrix[j*N + i].imag;
			test_imag_part = fabs(num_real_1 - num_real_2) <= ((fabs(num_real_1) < fabs(num_real_2) ? fabs(num_real_2) : fabs(num_real_1)) * eps);
			if (!test_real_part || !test_imag_part){
				result = false;
				break;
	return result;
void m_matrix_inversion(MKL_Complex16 *& matrix, int N){
	int i, j;
	bool test_if_symm;
	int *NLi = new int(N), *MLi = new int(N), *ldaLi = new int(N), *ipivLi = new int, *infoLi = new int(0);
	int lworkLi = -1;
	MKL_Complex16 *dummywork = new MKL_Complex16[1];
	test_if_symm = m_check_if_matrix_symmetric(matrix, N);
	if (test_if_symm){
		zsytrf("U", NLi, matrix, ldaLi, ipivLi, dummywork, &lworkLi, infoLi);
	}else{
		zgetri(NLi, matrix, ldaLi, ipivLi, dummywork, &lworkLi, infoLi);
	lworkLi = (int)(dummywork[0].real);
	MKL_Complex16 *work = new MKL_Complex16[lworkLi];
	if (test_if_symm){
		zsytrf("U", NLi, matrix, ldaLi, ipivLi, work, &lworkLi, infoLi);
		zsytri("U", NLi, matrix, ldaLi, ipivLi, work, infoLi);
			for (j = i + 1; j < N; j++){
				matrix[i*N + j] = matrix[j*N + i];
	}else{
		zgetrf(MLi, NLi, matrix, ldaLi, ipivLi, infoLi);
		zgetri(NLi, matrix, ldaLi, ipivLi, work, &lworkLi, infoLi);
	delete[] dummywork;
	delete[] work;
	delete NLi;
	delete MLi;
	delete ldaLi;
	delete[] ipivLi;
	delete infoLi;
	return;
void m_matrix_multiply(MKL_Complex16 *& matrix1, MKL_Complex16 *& matrix2, MKL_Complex16 *& matrix_res, int M, int N, int P, char * order, char * trans1, char * trans2){
	CBLAS_TRANSPOSE tr1 = CblasNoTrans, tr2 = CblasNoTrans;
	CBLAS_ORDER ord;
	int prv, sec;
	if (trans1 == "N"){
		tr1 = CblasNoTrans;
		prv = P;
	else if (trans1 == "T"){
		tr1 = CblasTrans;
		prv = M;
	else if(trans1 == "C"){
		tr1 = CblasConjTrans;
		prv = M;
	if (trans2 == "N"){
		tr2 = CblasNoTrans;
		sec = N;
	else if (trans2 == "T"){
		tr2 = CblasTrans;
		sec = P;
	else if (trans2 == "C"){
		tr2 = CblasConjTrans;
		sec = P;
	if (order == "R"){
		ord = CblasRowMajor;
	else{
		ord = CblasColMajor;
	cblas_zgemm(ord, tr1, tr2, M, N, P, &alpha, matrix1, prv, matrix2, sec, &beta, matrix_res, sec);
	return;
Ying_H_Intel
Hi Marko,
thank you for the sharing. we will check them and the performance.
Generally speaking, right  it is hard to see any obvious changes to improve to small matrix operation by any tips as the small matrix often means too less computation to find room to optimization.
Regarding zgemm,  there are other functions seems save some computation time theoretically
cblas_?gemm3m
Computes a scalar-matrix-matrix product using matrix multiplications and adds the result to a scalar-matrix
product.
Syntax
void cblas_cgemm3m (const CBLAS_LAYOUT Layout, const CBLAS_TRANSPOSE transa, const
CBLAS_TRANSPOSE
transb, const MKL_INT m, const MKL_INT n, const MKL_INT k
, const void
*alpha, const void *a, const MKL_INT lda, const void *b, const MKL_INT ldb
, const void
*beta, void *c, const MKL_INT ldc
void cblas_zgemm3m (const CBLAS_LAYOUT Layout, const CBLAS_TRANSPOSE transa, const
CBLAS_TRANSPOSE
, const void
, const void
Include Files
• mkl.h
Description
The ?gemm3m routines perform a matrix-matrix operation with general complex matrices. These routines are
similar to the
?gemm routines, but they use fewer matrix multiplication operations (see Application Notes
below).
or cblas_?gemmt
Computes a matrix-matrix product with general
matrices but updates only the upper or lower
triangular part of the result matrix
maybe you can try them.
secondly, do you have many of such kind of small matrix to do the computation?
If yes, you may try the batch gemm function
cblas_?gemm3m_batch
Computes scalar-matrix-matrix products and adds the
results to scalar matrix products for groups of general
matrices.
https://software.intel.com/sites/default/files/managed/7b/36/Batch-DGEMM-vs-GEMM-xeon-processor.png
Ying
SergeyKostrov
Valued Contributor II
>>...matrix inversions on matrices of the order 10x10 up to 50x50 most of the time (the maximum size would be somewhere >>around 200x200 but very rarely, they will almost exclusively be in the 10-50 range)... MKL functions overheads when small matrices are multiplied are significant and a classic matrix multiplication algorithm outperforms MKL's sgemm for sizes up to 2,048x2,048. I've spent some amount of time on evaluations and performance numbers could be reviewed at: https://software.intel.com/en-us/articles/performance-of-classic-matrix-multiplication-algorithm-on-intel-xeon-phi-processor-system
marko_m_
Hi everybody,
First of all, thank you for your effort and advices.I made a sample test program that compares mkl's zgemm and my implementations of matrix multiplication. Unfortunately it seems that my program is at least 2 to 2.5 times slower than mkl (which is expected, but I was full of hope after Sergey wrote the last message). Anyway i will post the code, what options I used in visual studio and if anyone can spot any errors, or give me some advice how to possibly accelerate my code, i would be very grateful. Even if the answer is negative, that is also good. So here goes the code:
#include <complex>
#include <cmath>
#include <vector>
#include <omp.h>
#include <Windows.h>
#include <algorithm>
#include <iomanip>
#include <iostream>
extern "C" {//
#include"mkl_cblas.h"
#include"mkl_lapack.h"
#include "mkl_service.h"
#include "mkl.h"
using namespace std;
const complex<double> alpha(1, 0), beta(0, 0);
#define CACHE_LINE  64
#define CACHE_ALIGN __declspec(align(CACHE_LINE))
*  @brief         Checks if the matrices that are compared, are they the same
*  @param[in]     matrix1       First matrix to compare
*  @param[in]     matrix2       Second matrix to compare to first element by element
*  @param[in]     N             Square matrix size
*  @return                      true if they are same, false otherwise
bool check_if_matr_match(MKL_Complex16 *& matrix1, MKL_Complex16 *& matrix2, int N){
	int i, j;
	double matr_1_real, matr_1_imag, matr_2_real, matr_2_imag;
	bool result = true;
		for (j = 0; j < N; j++){
			matr_1_real = matrix1[i*N + j].real;
			matr_1_imag = matrix1[i*N + j].imag;
			matr_2_real = matrix2[i*N + j].real;
			matr_2_imag = matrix2[i*N + j].imag;
			if ((fabs(matr_1_real) > 1.0000001*fabs(matr_2_real)) && ((fabs(matr_1_real) < 0.9999999*fabs(matr_2_real)))){
				return false;
			if ((fabs(matr_1_imag) > 1.0000001*fabs(matr_2_imag)) && ((fabs(matr_1_imag) < 0.9999999*fabs(matr_2_imag)))){
				return false;
	return result;
*  @brief         Simple wrapper around mkl zgemm function
void m_matrix_multiply_mkl(MKL_Complex16 *& matrix1, MKL_Complex16 *& matrix2, MKL_Complex16 *& matrix_res, int M, int N, int P, char * order, char * trans1, char * trans2){
	CBLAS_ORDER ord;
	int prv = 0, sec = 0;
	if (string(trans1) == "N"){
		tr1 = CblasNoTrans;
		prv = P;
	else if (string(trans1) == "T"){
		tr1 = CblasTrans;
		prv = M;
	else if (string(trans1) == "C"){
		prv = M;
	if (string(trans2) == "N"){
		tr2 = CblasNoTrans;
		sec = N;
	else if (string(trans2) == "T"){
		tr2 = CblasTrans;
		sec = P;
	else if (string(trans2) == "C"){
		sec = P;
	if (string(order) == "R"){
	else{
	return;
*  @brief         Simple wrapper around my matrix multiplication function
*  Bellow we have :
*    #define simple_mat_mul                                     this is the simplest implementation of a triple loop matrix multipication
*    #define simple_mat_mul_better_vars                         in my original program when I changed the the variables to be like this, I got a 40% increase in speed, but in this test program it doesn't appear to be the case
*    #define simple_mat_mul_transpose                           version where we first transpose the second matrix and then do the multiplicaton
*    #define simple_mat_mul_openmp                              like the transpose version but with openmp using 4 threads
//#define simple_mat_mul
//#define simple_mat_mul_better_vars
//#define simple_mat_mul_transpose
void m_matrix_multiply_mine(MKL_Complex16 *& matrix1, MKL_Complex16 *& matrix2, MKL_Complex16 *& matrix_res, int M, int N, int P, char * order, char * trans1, char * trans2){
	int i, j, k;
#ifndef simple_mat_mul
	double temp_var_1, temp_var_2;
	double c1r, c1i, c2r, c2i;
	MKL_Complex16 *temp_mat = new MKL_Complex16[P*N];
#endif
	for (int i = 0; i < M; i += 1){
		for (int j = 0; j < N; j += 1){
			matrix_res[i*N + j].real = 0.0;
			matrix_res[i*N + j].imag = 0.0;
#ifdef simple_mat_mul
	for (i = 0; i < M; i += 1){
		for (j = 0; j < N; j += 1){
			for (k = 0; k < P; k += 1){
				matrix_res[i*N + j].real += matrix1[i*P + k].real * matrix2[k*N + j].real - matrix1[i*P + k].imag*matrix2[k*N + j].imag;
				matrix_res[i*N + j].imag += matrix1[i*P + k].real * matrix2[k*N + j].imag + matrix1[i*P + k].imag*matrix2[k*N + j].real;
#endif
#ifndef simple_mat_mul_better_vars
			temp_mat[j*P + k] = matrix2[k*N + j];
#endif
#ifdef simple_mat_mul_openmp
#pragma omp parallel for private ( i, j, k, temp_var_1, temp_var_2, c1r, c1i, c2r, c2i) num_threads ( 4 )
#endif
			temp_var_1 = 0.0;
			temp_var_2 = 0.0;
				c1r = matrix1[i*P + k].real;
				c1i = matrix1[i*P + k].imag;
#ifdef simple_mat_mul_better_vars
				c2r = matrix2[k*N + j].real;
				c2i = matrix2[k*N + j].imag;
#endif
				c2r = temp_mat[j*P + k].real;
				c2i = temp_mat[j*P + k].imag;
#endif
				temp_var_1 += c1r*c2r - c1i*c2i;
				temp_var_2 += c1r*c2i + c1i*c2r;
			matrix_res[i*N + j].real = temp_var_1;
			matrix_res[i*N + j].imag = temp_var_2;
	delete[] temp_mat;
#endif
	return;
int main(){
	LARGE_INTEGER dsd_starting_time, dsd_ending_time, dsd_elapsed_microseconds_time_mkl, dsd_elapsed_microseconds_time_mine;
	LARGE_INTEGER Frequency;
	CACHE_ALIGN MKL_Complex16 *matr_1, *matr_2, *matr_3, *matr_4;
	unsigned long long int mkl_microsecond, mine_microseconds;
	int num_repetition = 20, num_start = 2, num_stop = 200;
	int iml_1, iml_2, i, j;
	MKL_Set_Num_Threads(MKL_Get_Max_Threads());
	QueryPerformanceFrequency(&Frequency);
	///Loop to traverse matrix sizes from num_start to num_stop
	for (iml_1 = num_start; iml_1 <= num_stop; iml_1++){
		mkl_microsecond = 0;
		mine_microseconds = 0;
		///Loop how many times to get total time and then average it with num_repetition
		for (iml_2 = 0; iml_2 < num_repetition; iml_2++){
			matr_1 = new MKL_Complex16[iml_1*iml_1];
			matr_2 = new MKL_Complex16[iml_1*iml_1];
			matr_3 = new MKL_Complex16[iml_1*iml_1];
			matr_4 = new MKL_Complex16[iml_1*iml_1];
			for (i = 0; i < iml_1; i++){
				for (j = 0; j < iml_1; j++){
					matr_1[i*iml_1 + j].real = 0.01 + (double)rand() / RAND_MAX*120.0;
					matr_1[i*iml_1 + j].imag = 0.01 + (double)rand() / RAND_MAX*120.0;
					matr_2[i*iml_1 + j].real = 0.01 + (double)rand() / RAND_MAX*120.0;
					matr_2[i*iml_1 + j].imag = 0.01 + (double)rand() / RAND_MAX*120.0;
					matr_3[i*iml_1 + j].real = 0.0;
					matr_3[i*iml_1 + j].imag = 0.0;
					matr_4[i*iml_1 + j].real = 0.0;
					matr_4[i*iml_1 + j].imag = 0.0;
			///MKL zgemm part
			QueryPerformanceCounter(&dsd_starting_time);
			m_matrix_multiply_mkl(matr_1, matr_2, matr_3, iml_1, iml_1, iml_1, "R", "N", "N");
			QueryPerformanceCounter(&dsd_ending_time);
			dsd_elapsed_microseconds_time_mkl.QuadPart = dsd_ending_time.QuadPart - dsd_starting_time.QuadPart;
			dsd_elapsed_microseconds_time_mkl.QuadPart *= 1000000;
			mkl_microsecond += dsd_elapsed_microseconds_time_mkl.QuadPart;
			///my implementation part
			m_matrix_multiply_mine(matr_1, matr_2, matr_4, iml_1, iml_1, iml_1, "R", "N", "N");
			dsd_elapsed_microseconds_time_mine.QuadPart = dsd_ending_time.QuadPart - dsd_starting_time.QuadPart;
			dsd_elapsed_microseconds_time_mine.QuadPart *= 1000000;
			mine_microseconds += dsd_elapsed_microseconds_time_mine.QuadPart;
			///Check if the calculated matrices by both methods give the same (approximately the same) result
			if (!check_if_matr_match(matr_3, matr_4, iml_1)){
				cout << "ERROR, matrices are not same :  " << iml_1 << "\n";
			delete[] matr_1;
			delete[] matr_2;
			delete[] matr_3;
			delete[] matr_4;
		///Output average times for mkl and my implementation
		cout << "Average times are (for size = " << iml_1 << " ):  mkl :   " << mkl_microsecond / num_repetition / Frequency.QuadPart << "          mine :   " << mine_microseconds / num_repetition / Frequency.QuadPart << "\n";
	return 1;
So I work with MKL_Complex16 matrices, so complex double is in play (MKL_Complex16), I used mkl version 10.0.012 but I can switch to mkl 2017 if someone thinks it would help. I work in Visual studio 2013, the target architecture is ia 32, I am in release mode, and from additional settings in project properties, and other,  I have:
- Debugging Environment _NO_DEBUG_HEAP=1
- C/C++ Optimizations /O2 and /Ot
- C/C++ code generation /MT and /fp:precise
- C/C++ Language /openmp
- Linker Optimizations /OPT:REF and /OPT:ICF
- Linker Advanced Image Has safe exceptions NO
- It is on windows (7 in my case)
- My CPU is Intel Core i7 2670 QM @ 2.20 GHz
If I missed something please let me know.
Additional questions:
1) Does openmp clash with mkl library or they can coexist in the same project? Is the above code correct in thos regard?
2) Is there any way to improve my codes execution times ?
3) If question 2) is a yes, and I can get it to be faster than mkl code for small matrices, is the same possible for matrix inversion?
Thank you all in advance :D
TimP
1. The intel libiomp5 required by mkl will displace the vs omp library and implement all msvc omp calls, includingimportant features like core affinity which Microsoft lacks. 2. Show Qvec-report results.
TimP
I'm not very familiar with the degree to which msvc supports AVX in 32-bit mode (why 32-bit mode?).  Evidently, x87 mode won't be competitive (don't even bother with vec-report).  As msvc doesn't support SSE3 code generation, you will have difficulty getting satisfactory performance with that compiler with /arch:SSE2.  You may need to split your data into separate real and imag arrays in order to take advantage of SSE2 or AVX vectorization.
Ying_H_Intel
Hi Marko,
I did test on one machine i5-6300,  Visual Studio 2015, release and 32bit model.  with MKL 2017 update 2.  Basically, when size < 32,  your self code had better performance than mkl.     INV operation is complex , so maybe same or better behaviors to use MKL instead of optimize your code.
Ying
MKL_VERBOSE Intel(R) MKL 2017.0 Update 2 Product build 20170126 for 32-bit Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2) enabled processors, Win 2.40GHz intel_thread
MKL_VERBOSE ZGEMM(N,N,2,2,2,003F6290,00C9F4E0,2,00C97E90,2,003F6280,00C9F528,2) 68.62us CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:2
Average times are (for size = 2 ):  mkl :   124654          mine :   9908
MKL_VERBOSE ZGEMM(N,N,12,12,12,003F6290,00CB5B10,12,00CB5208,12,003F6280,00CB6418,12) 40.15us CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:2
C:\Users\yhu5\Desktop\eigen\Fiona\Release>EU.exe
Average times are (for size = 2 ):  mkl :   144          mine :   244
Average times are (for size = 12 ):  mkl :   82          mine :   23
Average times are (for size = 22 ):  mkl :   55          mine :   30
Average times are (for size = 32 ):  mkl :   54          mine :   97
Average times are (for size = 42 ):  mkl :   59          mine :   119
Average times are (for size = 52 ):  mkl :   111          mine :   1196
Average times are (for size = 62 ):  mkl :   146          mine :   342
Average times are (for size = 72 ):  mkl :   171          mine :   546
Average times are (for size = 82 ):  mkl :   271          mine :   781
Average times are (for size = 92 ):  mkl :   516          mine :   783
Average times are (for size = 102 ):  mkl :   477          mine :   1007
Average times are (for size = 112 ):  mkl :   695          mine :   1440
Average times are (for size = 122 ):  mkl :   768          mine :   1469
Average times are (for size = 132 ):  mkl :   940          mine :   3289
Average times are (for size = 142 ):  mkl :   2289          mine :   6033
Average times are (for size = 152 ):  mkl :   1449          mine :   4930
Average times are (for size = 162 ):  mkl :   2230          mine :   6156
Average times are (for size = 172 ):  mkl :   2371          mine :   5887
Average times are (for size = 182 ):  mkl :   2783          mine :   5961
Average times are (for size = 192 ):  mkl :   3705          mine :   6690
Royi
By the way, few weeks ago I encountered an article of Intel about Intel MKL for improvement in MKL when one wants to multiply many matrices by the same matrix.
Anyone knows the link to this article?
Thank You.
Ying_H_Intel
Hi Royi,
do you mean another small matrix optimization compact format in MKL?
https://software.intel.com/en-us/articles/intelr-math-kernel-library-introducing-vectorized-compact-routines
One for larger matrix:
Packed APIs for GEMM
https://software.intel.com/en-us/articles/introducing-the-new-packed-apis-for-gemm
​Ying
