Solve Ax=b, where A is diagonal matrix
Ngu_Soon_Hui
I am trying to use LAPACK routines: linear equations to solve x in the linear equation system Ax=b. I know for sure that A is diagonal matrix, so which matrix type I should select? They are general, general band, triangular, triangular band but there is no diagonal matrix type!!
jonathandursi
Diagonal matrix, like Ai,j = 0 if i j ? If that's the case, why are you using a linear solver? xi = bi / Ai,i.
Alexander_K_Intel2
Your matrix is sparse so try to use PARDISO solver. Format for diagonal matrix is pretty simple (more detailes could be found in Intel Math Kernel Library ReferenceManual, Chapter 8)
With best regards,
Alexander Kalinkin
Ngu_Soon_Hui
Thanks alex.
I am aware that Pardiso is a choice.
But let's say if I am insisting on using LAPACK?
Alexander_K_Intel2
If you really want to use LAPACK for solving system of equation with diagonal matrix usebanded format for storing it.
With best regards,
Alexander Kalinkin
jonathandursi
