7291 Discussions
Solving a sequence of systems with identical sparsity patterns ?
Thierry_LE_SOMMER__E
I have to solve a sequence (iteration) of systems AX = B with multiple RHS.
At each iteration, X and B do not change and A changes but retains its sparsity patterns.
So I think I can use iparm[3]=62 but I know exactly how to use it.
B
elow is a summary of what I do :
Itration 1 :
iparm[3]=0;
phase=13;
pardiso(...);
Itration 2 :
iparm[3]=62;
phase=23;
pardiso(...);
Itration 3 :
iparm[3]=62;
phase=23;
pardiso(...);
I never release memory (phase=0 or -1) between iterations.
Is it the correct way to solve my problem ?
Thierry
Gennady_F_Intel
Thierry, please see this topic.
Thank you
I read the topic and I found a start of answer but I found nothing about iparm[3]
In my case, I have one matrix and therefore one memory address pointer PT.
I made a search with Google on this forum and I found my answer
What I do is correct but with iparm[3]=62 i see no speed up
I set iparm[3]=32 and now the speed up is there.
Sergey_Solovev__Inte
Hello!
What matrix type do you use?
If A changes and scaling and matching are used (iparm(11) and iparm(13)), so you should rerun phase 11.
Currently I use :
mtype = -2;
iparm[0] = 1;
iparm[1] = 2;
iparm[2] = 4;
iparm[3] = 32; //0 for the first iteration
iparm[59] = 1;
iparm[10] and iparm[12] are set to 0
It works fine with that
Sergey_P_Intel2
Hi, Thierry!
In the MKL documentation the description of the corresponding iparm(4) parameter contains the following lines:
" ... iparm(4) has the form iparm(4)= 10*L+K. ... The value L controls the stopping criterion of the Krylow-Subspace iteration: epsCGS = 10^-L is used in the stopping criterion...".
So for iparm[3] = 32 the value 10^-3 is used in the stopping criterion, while for iparm[3] = 62 the value 10^-6 is used which requires (significantly) more iterations than for stopping criterion 10^-3. I think that the reason ofthe described problem is in more strict conditions for iparm[3]=62 than for iparm[3]=32.
Sergey
