Sparse index base for export csr
marcsolal
I do not understand how is working the sparse_index_base in mkl_sparse_d_export_csr. It looks to me that the exported arrays are independant of what is chosen for sparse_index_base parameter. To explain, I am generating two csr sparse matrices using base one indexing. When I am exporting the csr arrays for one matrix the result always corresponds to one indexing independently of the parameter used for mkl_sparse_d_export_csr (SPARSE_INDEX_BASE_ZERO or SPARSE_INDEX_BASE_ONE). I am multiplying my two matrices using mkl_sparse_spmm. It looks the result of the multiplication is always in index base 0 independently of the parameter for the exporting function.
These are my results. The product is always in base 0 and the original matrix is exported in the same base it was generated. Can you please clarify, This is confusing. I am also attaching my code.
Marc
RESULTS:
PRODUCT
 row_start    0 3 7 12 17 22 27 32 37 41
 row_end      3 7 12 17 22 27 32 37 41 44
 col_indx     0 1 2 0 1 2 3 0 1 2 3 4 1 2 3 4 5 2 3 4 5 6 3 4 5 6 7 4 5 6 7 8 5 6 7 8 9 6 7 8 9 7 8 9
MATRIX2
 row_start    1 4 8 13 18 23 28 33 38 42
 row_end      4 8 13 18 23 28 33 38 42 45
 col_indx     1 2 3 1 2 3 4 1 2 3 4 5 2 3 4 5 6 3 4 5 6 7 4 5 6 7 8 5 6 7 8 9 6 7 8 9 10 7 8 9 10 8 9 10
#include <iostream>
using namespace std;
#include "mkl.h"
int main() {
	MKL_INT nRows=10;
	MKL_INT* rows=new MKL_INT[nRows];
	MKL_INT* cols=new MKL_INT [nRows];
//	MKL_Complex16* permutData=new MKL_Complex16[nRows];
	double *permutData=new double[nRows];
	for (int i=0;i<nRows;i++){
		rows=i+1;
		cols=i+1;
		permutData=1.0;
	sparse_matrix_t MATRIX1;
	sparse_status_t ok=mkl_sparse_d_create_coo (&MATRIX1,SPARSE_INDEX_BASE_ONE,nRows,nRows, nRows, rows,cols,permutData);
	if (ok==SPARSE_STATUS_SUCCESS){
		cout<<"Matrix done\n";
		cout.flush();
	else{
		cout<<"Problem in handle creation";
		cout.flush();
	MKL_INT* rows2=new MKL_INT[5*nRows];
	MKL_INT* cols2=new MKL_INT [5*nRows];
	double *Data=new double[5*nRows];
	MKL_INT nnz=0;
	for (int i=0;i<10;i++){
		for (int j=0;j<10;j++){
			if (abs(i-j)<=2){
				rows2[nnz]=i+1;
				cols2[nnz]=j+1;
				Data[nnz]=i-j;
				nnz++;
	cout<<"nnz :"<<nnz<<'\n';
	sparse_matrix_t MATRIX2;
	ok=mkl_sparse_d_create_coo (&MATRIX2,SPARSE_INDEX_BASE_ONE,nRows,nRows, nnz, rows2,cols2,Data);
		cout.flush();
	else{
		cout.flush();
	sparse_matrix_t MATRIX1CSR;
	ok=mkl_sparse_convert_csr(MATRIX1,SPARSE_OPERATION_NON_TRANSPOSE,&MATRIX1CSR);
	if (ok!=SPARSE_STATUS_SUCCESS){
		cout<<"Problem in conversion\n";
		cout.flush();
	sparse_matrix_t MATRIX2CSR;
	ok=mkl_sparse_convert_csr(MATRIX2,SPARSE_OPERATION_NON_TRANSPOSE,&MATRIX2CSR);
		cout.flush();
	sparse_matrix_t PRODUCT;
	ok= mkl_sparse_spmm(SPARSE_OPERATION_NON_TRANSPOSE,MATRIX1CSR,MATRIX2CSR,&PRODUCT);
		cout<<"Problem in matrix export\n";
		cout.flush();
	MKL_INT nRowsPROD,nColsPROD;
	MKL_INT* rows_start;
	MKL_INT* rows_end;
	MKL_INT* col_indx;
	double* values;
	sparse_index_base_t indexing=SPARSE_INDEX_BASE_ONE;
	ok=mkl_sparse_d_export_csr(PRODUCT,&indexing,&nRowsPROD,&nColsPROD,&rows_start,&rows_end,&col_indx,&values);
	cout<<"\nPRODUCT";
	cout<<"\n row_start\t";
	for (int i=0;i<nRowsPROD;i++){
		cout<<rows_start<<" ";
	cout<<"\n row_end  \t";
		cout<<rows_end<<" ";
	cout<<"\n col_indx \t";
	for (int i=0;i<nnz;i++){
		cout<<col_indx<<" ";
	cout<<'\n';
	MKL_INT nRows2,nCols2;
	MKL_INT* rows_start2;
	MKL_INT* rows_end2;
	MKL_INT* col_indx2;
	double* values2;
	sparse_index_base_t indexing2=SPARSE_INDEX_BASE_ZERO;
	ok=mkl_sparse_d_export_csr(MATRIX2CSR,&indexing2,&nRows2,&nCols2,&rows_start2,&rows_end2,&col_indx2,&values2);
	cout<<"\nMATRIX2";
	for (int i=0;i<nRows2;i++){
		cout<<rows_start2<<" ";
		cout<<rows_end2<<" ";
		cout<<col_indx2<<" ";
	cout<<'\n';
	return 0;
Ying_H_Intel
Thanks for the report. It is real good question.  the parameter indexing in the function mkl_sparse_d_export_csr was output parameter, not a input parameter. so it seems the function always return 0 based csr matrix.  We will check in detail and get back to you later.
Ying
Alexander_K_Intel2
Ying is correct, indexing in export routines is output parameter so it filled after export execution it correspond to indexing that used for internal data
Alex
marcsolal
I did not see it. It was obvious to me it had to be an input parameter to let me decide the indexing I like. It appears that he indexing is changed to 1 based when multiplying two sparse matrices. I will add a test inside my code.
Thanks a lot,
Marc
marcsolal
 Another question on the same topic. I am exporting csr to use my matrix in PARDISO. Is there a way to make sure the column indexes are sorted or do I need to sort it myself after exporting.
Alexander_K_Intel2
In current version of MKL you need to sort csr format to garantee correctness of input pardiso data
Alex
marcsolal
I understand that. Is there any way to do this sorting inspector executor interface to sparse blas routines? I see that many regular sparse blas routines have sorting options. It would be nice to have something similar when using inspector executor.
Marc
