7302 Discussions
Speed up performance for a given matrix structure
Dinesh_S_
Hi
If the logical structure (not actual values) of the matrix remains same, is there a way to avoid symbolic factorization stage for problems requiring large number of of linear system solutions?
Dinesh
Gennady_F_Intel
you may set maxfct ( maximum #of factors with identical sparsity structure) accordingly your case, make symbolic factorizations only once and then do numerical factorization maxfct times. we have a couple of examples show these cases.
Dinesh_S_
Could you please direct me to an example to achieve this?
My problem involve solving many linear systems (to obtain solution to non linear system)
For example, I would like to solve
A1 x1 = b1
then
A2 x2 = b2
where A2 depends on x1, but the sparsity of A1 and A2 are the same (however I do not have A2 until I solve for x1)
Dinesh
