Starting with mkl
renepreto
Hi mkl users! I've just installed mkl under fedora 9 and I have some codes that i would like to run using mkl libraries, so I have to know how to do it properly. I have tried the following example:
Program Teste
implicit none
integer n,i,incx,incy
parameter (n=4, incx=1,incy=1)
real x(n), y(n), res, sdot
external sdot
do i=1,n
x(i)=i
y(i)=2*i
enddo
res=sdot(n,x,incx,y,incy)
print*, 'sdot =',res
open (unit=1, file='resultado', status='unknown')
write(1,*)res
end
but when I try
ifort -L/opt/intel/mkl/10.0.5.025/lib/em64t teste.for
[rene@Rene Teste mkl]$ ifort -L/opt/intel/mkl/10.0.5.025/lib/em64t teste.for
/tmp/ifortF8bXCF.o: In function `MAIN__':
teste.for:(.text+0x96): undefined reference to `sdot_'
I've heard that I schould try
ifort -L/opt/intel/mkl/10.0.5.025/lib/em64t -l'librarie name' teste.for
but how do I know what the librarie name? there is no sdot there? is there an easier way?
Gennady_F_Intel
1.Hello, please try to use the following building command line:
ifort -w test.f ${MKLROOT}/libmkl_intel_lp64.a -Wl,--start-group ${MKLROOT}/libmkl_intel_thread.a ${MKLROOT}/libmkl_core.a -Wl,--end-group -L${MKLROOT} -liomp5 -lpthread -o test.out
where for example MKLPATH=/opt/intel/mkl/10.0.5.025/lib/em64t
2. more info about the MKL linking models, examples and so , you can find into userguide manual.
--Gennady
renepreto
Hey! thanks for the answer, but when I try to open the test.out it shows the following error
error while loading shared libraries: libiomp5.so: cannot open shared object file: No such file or directory
but if I try the command line without the -liomp5, everything is ok! what does this lib do? thanks, and i've got the userguide and reading it already!
TimP
Quoting - renepreto
If you don't use any OpenMP threaded functions, or use the sequential stub library in place of the thread library, you don't require the OpenMP library. When you link against the OpenMP shared library, the LD_LIBRARY_PATH setting is required to find it at run time. Depending on your mkl version, there would be mklvars scripts to set the PATH variables, or (in the latest Intel compilers) it would be included in the corresponding compiler environment setting scripts.
renepreto
thanks again! I've read this in the userguide but i am not really sure what to do. i am using mkl 10.0.5.025 and ifort 10.1.018. may someone explain me with more details?
TimP
Quoting - renepreto
Running both the ifortvars script in the Fortran installation, and the mklvars script in the MKL installation, will set all the PATH variables required by those products.
