Tridiagonal system and PARDISO
xavier_lacroze
I need to solve two tridiagonal (non symmetric though) systems at each time step (coming from a split finite difference scheme). My strategy was as follow:
- define two context handles pt1 and pt2
- perform symbolic factorization (phase 11) on each system
- then at each time step, use a preconditioned CGS and solve the systems (phase 23)
Unfortunately, I found no speed improvment wether I used preconditioned CGS or not. Also, solving this tridiagonal systems with PARDISO is like 10 times slower than solving it with LAPACK dgtsv()...
Am I missing something ?
Thanks for your advices,
Xavier
TimP
It seems unlikely that you could improve on the dgtsv algorithm, if you require its generality. The point of CG schemes is to solve problems with in-band sparsity, which would be exclusive of those where dgtsv could be applied directly.
xavier_lacroze
Thank you for your reply.
Xavier
