Using Colamd with Pardiso
damienhocking
Hi all,
I was wondering if anyone has used Colamd with Pardiso. Given that colamd is a column reordering and Pardiso is a row-ordered solver this might be slow because the matrix would have to be reordered into column form. Anyone tried this? I'm trying Scotch out right now as well.
Damien
ArturGuzik
Valued Contributor I
Quoting - damienhocking
Damien,
what do you mean by that?
A.
damienhocking
Quoting - ArturGuzik
Damien,
A.
Pardiso requires the matrix in row-major format. Colamd requires the matrix in column-major format. There would need to be a reordering pass and a separate structure stored to map the reordering back to row-major.
This is starting to look like more CPU work than it could be worth.
Gennady_F_Intel
Damien,
Yes, it will require more CPU work, however we don't expect the visible slowdown of PARDISO.
The slowdown will be negligible especially for the big problem sizes.
--Gennady
damienhocking
Damien,
--Gennady
I have a client with some difficult and badly-scaled matrices from their simulation environment. With some careful scaling in my nonlinear solver, the parallel METIS ordering is doing a good enough job and Pardiso solves everything now with good speedups on multicores.
Damien
