7303 Discussions
Using fgmres to solve large-scale linear equation systems
houjy
 I have used ILP64 successfully.
But I have another question,When I use fgmres to solve large systems of linear equations, some values in the ipar array are equal to -5589219598436180572
This is my code example. I would like to try solving a system of linear equations with a scale of 69335390 or above. Thank you very much.
Ruqiu_C_Intel
Thank you for contacting us for help. It's helpful if you can provide us a simple reproducer, compiler, compile options, OS, and CPU information..
Ruqiu
houjy
Thank you very much!
reproducer:
visual studio2019(release x64),win 10
compiler,compile options:Optimization:/O2L;Preprocessor Definitions:NDEBUG
_CONSOLE;Warning Level:/W3
OS:windows
CPU information:CPU 为Intel(R) Xeon(R) Platinum 8269CY,1023G
I don't know if the information I provided is comprehensive.
Mahan
Hello houjy,
Could you please provide a sample code to reproduce this issue.
houjy
谢谢。我已经在之前的回复中上传了我的代码。我还需要提供任何进一步的细节吗
houjy
Thank you very much. I have already uploaded my code in my previous reply. Is there any further detail that I need to provide
Mahan
Hi houjy,
Got it, thanks.
Please allow us a few days to get back to you.
Mahan
Hello houjy,
The following dependency is missing while compiling the code
"fmm.hpp"
Please include that with the reproducer.
Also, does it require an Eigen library?
houjy
Thank you very much. The function of "fmm. hpp" is to generate a system of linear equations Ax=b, and it does not use the engin library.
Because the entire project file is a huge amount of code, I rewrote the code for randomly generating a system of linear equations.
After each iteration of the code, there is a problem with RCI_request=4 for the second time. Could you please help me find where the problem lies. This problem only occurs when calculating a scale of billions.
houjy
#include <cstdio>
#include <vector>
#include <mkl.h>
#include <mkl_spblas.h>
#include <random>
#include <iostream>
using std::vector;
using namespace std;
int main() {
// 设置问题规模N(上亿)
MKL_INT N = 100000000; // 1亿
MKL_INT M =350; // GMRES的restart频率
// 为随机数生成器设定种子
std::mt19937 gen(1500);
std::uniform_real_distribution<> dist(-1.0, 1.0);
// 创建稀疏矩阵A,使用CSR格式
// 假设A每行最多有10个非零元素(具体数值视问题而定)
vector<MKL_INT> ia(N + 1, 0); // 行指针初始化为0
vector<MKL_INT> ja; // 列索引
vector<double> a; // 非零值
// 随机生成稀疏矩阵
for (MKL_INT i = 0; i < N; ++i) {
ia[i] = static_cast<MKL_INT>(ja.size()) + 1; // 记录当前行的起始位置
for (MKL_INT j = 0; j < 10; ++j) {
MKL_INT col_idx = i + j; // 为了简单起见,假设对角线附近有非零值
if (col_idx >= N) break; // 防止越界
ja.push_back(col_idx + 1); // 列索引从1开始
a.push_back(dist(gen)); // 随机生成非零元素
ia[N] = static_cast<MKL_INT>(ja.size()) + 1; // 记录最后一行的结束位置
// 随机生成右端项b
vector<double> b(N);
b[i] = dist(gen);
// 初始化GMRES求解器
MKL_INT ipar[128] = { 0 };
double dpar[128] = { 0 };
MKL_INT fan = N * (2 * M + 1) + (M * (M + 9)) / 2 + 1;
cout << "值" << N * (2 * M + 1) + (M * (M + 9)) / 2 + 1 << endl;
double* tmp = new double[70100062826];
vector<double> computed_solution(N, 0.0); // 初始解为0
MKL_INT RCI_request = 0;
MKL_INT itercount = 0;
DFGMRES_INIT(&N, computed_solution.data(), b.data(), &RCI_request, ipar, dpar, tmp);
if (RCI_request != 0) {
std::cerr << "Initialization failed" << std::endl;
return -1;
// 设置GMRES参数
ipar[14] = M; // GMRES重启频率
ipar[7] = 1; // 启动最大迭代次数
ipar[8] = 1; // 启动残差检测
ipar[10] = 1; // 启动预处理
// 主循环,执行FGMRES求解
while (true) {
DFGMRES(&N, computed_solution.data(), b.data(), &RCI_request, ipar, dpar, tmp);
itercount++; // 增加迭代次数
if (RCI_request == 0) break; // 解得出结果
if (RCI_request == 1) {
// 计算 A * tmp[ipar[21] - 1] 并存储在 tmp[ipar[22] - 1]
mkl_dcsrgemv("N", &N, a.data(), ia.data(), ja.data(), &tmp[ipar[21] - 1], &tmp[ipar[22] - 1]);
else if (RCI_request == 3) {
// 应用预处理器(可选,可以自定义预处理器)
tmp[ipar[22] - 1 + i] = tmp[ipar[21] - 1 + i]; // 此处为单位预处理器
else if (RCI_request == 2) {
std::cout << "Iteration " << itercount << ": Residual = " << dpar[4] << std::endl;
if (dpar[4] < dpar[0]) break; // 满足残差要求
// 完成后输出结果
std::cout << "FGMRES completed in " << itercount << " iterations." << std::endl;
// 清理内存
delete[] tmp;
return 0;
Mahan
Hello houjy,
Please provide the necessary dependencies pointed out in the previous message.
Mahan
houjy
The reproducer has quite a bit of memory leakage; please look into that.
You can find out more about the memory leakage by using the following command to compile the code
icpx -O0 -g -traceback -fsanitize=address -qmkl test_fgmres.cpp
houjy
Because we are using a different compilation environment, may I ask if the memory overflow you mentioned is after calling the fgmers function:
Mahan
houjy
The memory overflow is happening during the call
at line number 55.
houjy
Thank you very much. Unfortunately, I just wanted to seek help to solve the problem with line 55. I found that there is no memory overflow when the generated matrix size is small, but memory overflow occurs when the code size is over one billion
Mahan
Hi houjy
Thanks for the confirmation.
Does your system have enough memory to handle large matrices for which you are facing this memory overflow issue?
houjy
Thank you for your help
My computer has enough memory. My computer has 1TB of memory, and this code requires approximately 13GB of memory
Mahan
Hi houjy
This issue has been communicated to the developers, allow us a few days to get back to you.
Mahan
Hi houjy
In the reproducer the matrix dimension and the size of the Klyrov subspace:
MKL_INT N = 100000000; // the matrix dimension
MKL_INT M =350; // the size of Krylov subspace
It is easy to check that M*N= 35 000 000 000 exceeds INT_MAX = 2 147 483 647 for 32-bit Integers.
Could you please reduce the N size so that it does not exceed the INT_MAX and check?
houjy
Thank you very much
But I am using 64 bit and ILP64, max MKL_INT=9223372036854775807
Mahan
Could you please try compiling with the following
-DMKL_ILP64 -qmkl-ilp64=parallel
