7303 Discussions
Using fgmres to solve large-scale linear equation systems
houjy
 I have used ILP64 successfully.
But I have another question,When I use fgmres to solve large systems of linear equations, some values in the ipar array are equal to -5589219598436180572
This is my code example. I would like to try solving a system of linear equations with a scale of 69335390 or above. Thank you very much.
houjy
May I ask what this means? The environment I am using is the Visual Studio compiler for Windows
houjy
Is there any other solution or elimination method
Chao_Y_Intel
MKL_INT is used in the code. It need to add "MKL_ILP64" micro to define this type as 64 bit integer.
To compiler it with MSVC compiler:
1)Set the Target Application to x64 (64-bit Code):
2)Add the MKL_ILP64 Micro Definition:
Go to Project > Properties > C/C++ > Command Line.
In the Additional Options box, add the following micro definition: /DMKL_ILP64
3)Add ILP64 Libraries to the Linker:
 Project > Properties window > Linker > Input. Add the following ILP64 libraries in
  mkl_intel_ilp64.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib
4)Also need to set the include/ Library library path:
 Project>Properties > VC++ Directories> Include Directories, Add MKL Include Path: xxx\mkl\latest\include
Project>Properties >Linker >General >Additional Library Directories, Add MKL library Path:  xxx\mkl\latest\lib
