7299 Discussions
Using pdgetrf and pdgetri for Matrix inversion in C++
chris6
I am trying to use scaLapack to inverse a 120k x 120k matrix with `pdgetrf` and `pdgetri` . I have found an example of matrix inversion using `pdgetrf` and `pdgetri` :
#include <mpi.h>
#include <cstdio>
#include <cassert>
//#include "block_cyclic_mat.h"
#include <mkl.h>
#include "mkl_scalapack.h"
#include <vector>
#include <memory>
using namespace std;
static double getri_flops(int N)
// From:
// https://icl.cs.utk.edu/svn/scalapack-dev/scalapack/trunk/TESTING/LIN/pdinvdriver.f
// Factorization: 2/3 N^3 - 1/2 N^2
// Inverse : 4/3 N^3 - N^2
return ((2.0/3.0 * N * N * N) - (1.0/2.0 * N * N) +
(4.0/3.0 * N * N * N) - (N * N))/1024.0/1024.0/1024.0;
/// n_global: the order of the matrix
static void inv_driver(int n_global)
auto grid = make_shared<blacs_grid_t>();
//// self code
//n_global = 3;
//double *aaa = new double(n_global*n_global);
//for (int i = 0; i < 9; i++)
// aaa[i] = i + 1;
//aaa[8] = 10;
//auto a = block_cyclic_mat_t::createWithArray(grid, n_global, n_global, aaa);
// Create a NxN random matrix A
auto a = block_cyclic_mat_t::random(grid, n_global, n_global);
// Create a NxN matrix to hold A^{-1}
auto ai = block_cyclic_mat_t::constant(grid, n_global, n_global);
// Copy A to A^{-1} since it will be overwritten during factorization
copy_n(a->local_data(), a->local_size(), ai->local_data());
MPI_Barrier (MPI_COMM_WORLD);
double t0 = MPI_Wtime();
// Factorize A
int ia = 1, ja = 1;
vector<int> ipiv(a->local_rows() + a->row_block_size() + 100);
int info;
//å«ä¹åºè¯¥æ¯D-GE-TRFã
//第ä¸ä¸ªD表示æä»¬çç©éµæ¯doubleç±»åç
//GE表示æä»¬çç©éµæ¯Generalç±»åç
//TRF表示对ç©éµè¿è¡ä¸è§åè§£ä¹å°±æ¯æä»¬é常æè¯´çLUåè§£ã
pdgetrf_(n_global, n_global,
ai->local_data(), ia, ja, ai->descriptor(),
ipiv.data(),
info);
assert(info == 0);
double t_factor = MPI_Wtime() - t0;
// Compute A^{-1} based on the LU factorization
// Compute workspace for double and integer work arrays on each process
int lwork = 10;
int liwork = 10;
vector<double> work (lwork);
vector<int> iwork(liwork);
lwork = liwork = -1;
// 计ç®lworkä¸liworkçå¼
pdgetri_(n_global,
ipiv.data(),
work.data(), lwork, iwork.data(), liwork, info);
assert(info == 0);
lwork = static_cast<int>(work[0]);
liwork = static_cast<size_t>(iwork[0]);
work.resize(lwork);
iwork.resize(liwork);
// Now compute the inverse
t0 = MPI_Wtime();
pdgetri_(n_global,
ipiv.data(),
assert(info == 0);
double t_solve = MPI_Wtime() - t0;
// Verify that the inverse is correct using A*A^{-1} = I
auto identity = block_cyclic_mat_t::diagonal(grid, n_global, n_global);
// Compute I = A * A^{-1} - I and verify that the ||I|| is small
char nein = 'N';
double alpha = 1.0, beta = -1.0;
pdgemm_(nein, nein, n_global, n_global, n_global, alpha,
a->local_data() , ia, ja, a->descriptor(),
beta,
identity->local_data(), ia, ja, identity->descriptor());
// Compute 1-norm of the result
char norm='1';
work.resize(identity->local_cols());
double err = pdlange_(norm, n_global, n_global,
identity->local_data(), ia, ja, identity->descriptor(), work.data());
double t_total = t_factor + t_solve;
double t_glob;
MPI_Reduce(&t_total, &t_glob, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD);
if (grid->iam() == 0)
double gflops = getri_flops(n_global)/t_glob/grid->nprocs();
printf("\n"
"MATRIX INVERSE BENCHMARK SUMMARY\n"
"================================\n"
"N = %d\tNP = %d\tNP_ROW = %d\tNP_COL = %d\n"
"Time for PxGETRF + PxGETRI = %10.7f seconds\tGflops/Proc = %10.7f, Error = %f\n",
n_global, grid->nprocs(), grid->nprows(), grid->npcols(),
t_glob, gflops, err);fflush(stdout);
int main(int argc, char** argv)
MPI_Init(&argc, &argv);
int n_global = 4096;
if (argc > 1)
n_global = int(atol(argv[1])); // stol å­ç¬¦ä¸²è½¬é¿æ´å½¢
inv_driver(n_global);
MPI_Finalize();
I tried to compile this source in the following way :
mpicxx -I/opt/intel/oneapi/mpi/latest/include -L${MKLROOT}/lib/intel64 -lmkl_scalapack_ilp64 -lmkl_intel_ ilp64 -lmkl_intel_thread -lmkl_core -lmkl_blacs_intelmpi_ilp64 -liomp5 -lpthread -lm -ldl main.cpp
But I get the following errors :
main.cpp: In function ‘void inv_driver(int)’:
main.cpp:27:29: error: ‘blacs_grid_t’ was not declared in this scope
main.cpp:27:29: note: suggested alternative: ‘clockid_t’
clockid_t
main.cpp:27:43: error: no matching function for call to ‘make_shared<<expression error> >()’
In file included from /usr/include/c++/8/memory:81,
from main.cpp:8:
/usr/include/c++/8/bits/shared_ptr.h:718:5: note: candidate: ‘template<class _Tp, class ... _Args> std::shared_ptr<_Tp> std::make_shared(_Args&& ...)’
make_shared(_Args&&... __args)
/usr/include/c++/8/bits/shared_ptr.h:718:5: note: template argument deduction/substitution failed:
main.cpp:27:43: error: template argument 1 is invalid
main.cpp:41:14: error: ‘block_cyclic_mat_t’ has not been declared
main.cpp:44:15: error: ‘block_cyclic_mat_t’ has not been declared
main.cpp:47:5: error: ‘copy_n’ was not declared in this scope
main.cpp:47:5: note: suggested alternative: ‘ctpcon’
ctpcon
main.cpp:100:21: error: ‘block_cyclic_mat_t’ has not been declared
main.cpp:105:5: error: ‘pdgemm_’ was not declared in this scope
main.cpp:105:5: note: suggested alternative: ‘pdgels_’
pdgels_
I couldn't find into my OneAPI installation the header `"block_cyclic_mat.h"`.
Moreover, I get a lot of same error about `"block_cyclic_mat_t"` with : `"error: ‘block_cyclic_mat_t’` has not been declared"
By the way, I have also errors about `"blacs_grid_t’` was not declared in this scope" and `"error: no matching function for call to ‘make_shared<<expression error> >()’ "`
Does anyone see what's wrong and if this is the case, how to circumvent these compilation errors ?
Best regards
HemanthCH_Intel
Hi Chris,
We suppose that blacs_grid_t and block_cyclic_mat_t are user defined routines. So, could you please include the related code ?
or
Could you please use Intel oneAPI MKL Library related routines .
>>> I have also errors about `"blacs_grid_t’` was not declared in this scope".
Please refer to the below link for using  blacs and change the code accordingly.
https://www.intel.com/content/www/us/en/develop/documentation/onemkl-developer-reference-c/top/blacs-routines/blacs-support-routines/initialization-routines.html#initialization-routines
For using pdgemm, please include "mkl_pblas.h" in your code.
Please refer to the below link for more details.
https://www.intel.com/content/www/us/en/develop/documentation/onemkl-developer-reference-c/top/pblas-routines/pblas-level-3-routines/p-gemm.html#p-gemm
Thanks & Regards,
Hemanth.
chris6
Hi Hemanth !
Thanks for your support. The code I posted above comes from the following link :
https://cpp.hotexamples.com/site/file?hash=0x997241836033d9ef832d155f2515172857071833425d44fbaa0fe82464fedf5d&fullName=inverse.cpp&project=flySword/C-
I didn't find on inte.com documentation a simple example of matrix inversion with ScaLapack.
Could you provide please a simple example which uses MPI and the Intel OneAPI routines of ScaLapack to invert large matrix. I have at work
a worstation which has 1TB RAM and 64 cores with 2 GPU RTX A6000 which gives 96GB.
I would be grateful if you can show me this basic example.
Best regards
HemanthCH_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & regards,
Hemanth.
chris6
I have posted an update of my issue above.
I didn't think that it would be such difficult to have a simple example of matrix inversion with ScaLapack.
HemanthCH_Intel
We are working on your issue, we will get back to you soon.
Hemanth.
Gennady_F_Intel
You could re-use these ScaLAPACK examples which are ready to take and build: https://github.com/flySword/C-
All common header files like block_cyclic_mat.h and others You could find out into Common directory.
The only thing you have to do is link against MKL. Here is the link to the MKL User Adviser to see how to link with ScaLAPACK API correctly: https://www.intel.com/content/www/us/en/developer/tools/oneapi/onemkl-link-line-advisor.html
At this moment we don't have a "C" API examples to share. The Corresponding Feature Request would open and probably these examples will be added in one of the future versions of oneMKL.
Right now, the thread is closing and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
--Gennady
