VSL for Convolution
Paul_S_Intel2
I'm getting started with using MKL VSL for convolutions. For learning, I first I want to conduct a 1D convolution. I'm confused with the usage example given here: https://software.intel.com/en-us/node/521925 because it seems the naming and terminology is different than on the other description links.
In the other reference material there is mention of xstride, ystride etc. Where are those in this example? Where do you set the parameter dim? What would be an example of the set up and call for convolution of, say x and y:
x[0]=1
x[1]=2
x[2]=3
x[3]=4
x[4]=5
y[0]=1
y[1]=2
y[2]=3
y[3]=4
y[4]=5
Thanks!
Paul Safier
[email protected]
Zhen_Z_Intel
Hi Paul,
There's no entry point (main function) of this sample, you could not build it directly. If you would like to learn how to use this function and test, please find MKL samples' source code in your MKL installation path. And the main function which is used to initialize data and call scond sub routine and is saved in:
%MKLROOT%\examples_core_c\vslc\essl\sample_scond.c
And the code for MKL scond function is saved in:
%MKLROOT%\examples_core_c\vslc\essl\vsl_wrappers\sample_scond.c
Please following this example to test, Thank you.
Fiona
Paul_S_Intel2
Thanks Fiona!
