pardiso error with a particular set of data
LRaim
Today in running a simulation test case I have found the following error:
See attached txt file since by copying the test I received 'Your submission contains invalid characters ....".
The compiler used is: Compiling with Intel(R) Visual Fortran Compiler XE 15.0.6.285 [IA-32]
The interface with PARDISO is not changed from about 2 years and it is the first time I get such an error.
Can I get some additional info by using MSGLVL value now set to 0 ?.
Gennady_F_Intel
I see no txt file into attachment. Could you get it.
LRaim
Attached should be the error trace as: error1.txt.
​I can see this information :
direct download link: /file/520194/download
under : Attach file to post -> Attachments -> file information   but such information disappears by pushing 'Preview'
Gennady_F_Intel
error.txt contains the messages:
Xdsim10.exe!_mkl_pds_psol_bwscat_pardiso()    Unknown
libiomp5md.dll!0fe527e5()    Unknown
[Frames below may be incorrect and/or missing, no symbols loaded for libiomp5md.dll]
xmeth00.dll!0f764417()    Unknown
Xdsim10.exe!_free_base(void * pBlock) Line 50    C
Have you added the mkl's and compiler's dynamic libraries to the system path?
LRaim
I always include and deliver specific dll in the program directory. MKL are linked with the executable.
libiomp5md.dll is included in the program executable directory
I have found this error with a particular set of input data. By changing slightly input data no error is found.
The subsequent trace back is not correct, pardiso is called through a quite long sequence of subroutine calls. Autoparallelization is not used in the project, about this topic I created recently a discussion in the in the 'compiler' forum and the application is the same.
​This week I am out of the office so some answers could be delayed.
I plan to run the same case excluding pardiso and using a classical linear system solution algorithm.
Best regards
