Why the include path is always wrong?
xu_jocelyn
A program contains mkl_vsl functions. I have some codes as follow,
"Use MKL_VSL
TYPE(VSL_CONV_TASK) :: task
status = vsldConvNewTaskX1D(task,VSL_CONV_MODE_DIRECT,Nt,Nt,Nt,Ram_par,1)
status = vsldConvExecX1D(task,It_1D,1,Ram,1)
errcode = vslConvDeleteTask(task)"
I have already set in IVF,
1) Tools-Options-Compiler Seletion (Libraries-C:Program Files (x86)IntelMKL10.0.012em64tlib, Includes-C:Program Files (x86)IntelMKL10.0.012include)
2) Project--Linker-Input-additional dependencies(mkl_dll.lib libguide40.lib).
3) Running the mklvarsem64t.bat file...
Moreover, the beginning of the program contains "Use MKL_VSL". Afterabve setting, compilation is not completed yet. It still show that,
F:....f90(384) : Error: Error in opening the compiled module file. Check INCLUDE paths. [MKL_VSL]
F:....f90(389) : Error: This derived type name has not been declared. [VSL_CONV_TASK]
F:....f90(416) : Error: This name does not have a type, and must have an explicit type. [TASK]
F:...(416) : Error: This name does not have a type, and must have an explicit type. [VSL_CONV_MODE_DIRECT]
F:....f90(416) : Error: This name does not have a type, and must have an explicit type. [VSLDCONVNEWTASKX1D]
F:....f90(417) : Error: This name does not have a type, and must have an explicit type. [VSLDCONVEXECX1D]
F:...f90(418) : Error: This name does not have a type, and must have an explicit type. [VSLCONVDELETETASK]
What'swrong with it? I really have no idea... Could you give me some advices?
btw: I have use the mkl_dfti funcions in the same program quite well.. (It has to use the command "ifort -c mkl_dfti.f90" to creat "mkl_dfti.mod". However, there is "mkl_vsl.fi" only. SoI am afraid that the"mkl_vsl.mod"could not be created. Is it right?)What problem occurs in the mkl_vsl?
Thank you so much!
The INCLUDE path is not necessarily "wrong", but I'll agree that there is no mkl_vsl.mod in the folders you have mentioned. It is not clear to me what MKL intends you to do here - I can see documentation on building the BLAS and LAPACK95 interfaces, but not for VSL. I am going to move this question to the MKL forum for response from MKL experts.
