ZYTRI sequential?
Olaf_Schenk
Hi
I am testing the following code with composer_xe_2015
lwork = 256*n
call ZSYTRF( 'U', n, afull, n, ipiv, work, lwork, error )
call ZSYTRI( 'U', n, afull, n, ipiv, work, lwork, error )
using
gfortran -O3 -fopenmp  read_blas.f90 -Wl,--start-group ${MKLROOT}/lib/intel64/libmkl_gf_lp64.a ${MKLROOT}/lib/intel64/libmkl_core.a ${MKLROOT}/lib/intel64/libmkl_gnu_thread.a -Wl,--end-group -ldl -lpthread -lm
After setting OMP_NUM_THREADS=16 I can see in "top" that  ZSYTRF runs in parallel but ZSYTRI not. The matrix is large enough (n=15120)
Any idea how to solve this problem?
Olaf
Ying_H_Intel
Hi Olaf
You are right, the function is not threaded. Here is threaded function list for your reference.
https://software.intel.com/en-us/articles/intel-mkl-threaded-functions/
As i understand, you actually expect the function is parallel so improve the performance, right?  If yes, could you please let me know some information, like background, problem size, hardware etc. If private information, you may reply me by Private message.
Ying
