7267 Discussions
about efficiency variation of MKL Pardiso from XE cluster 2020 to intel oneapi in fortran compiler
xqbc
I once download a free version of  Intel® Parallel Studio XE Cluster Edition 2020, it showed very good computation ability when I used pardiso with my PC with 2*Intel(R) Xeon(R) CPU E5-2630 v4. The CPU utilization can reached 100%. However, it was expired now. I now used intel oneapi HPC on VS, however, I can only reach 50% cpu utilization when I used Pardiso for solver.  And the computation time is about two times in oneapi than that in cluster 2020. The Fortran project setting is same in both cases, I do not know the problem.
ShanmukhS_Intel
Hi Qibin,
Thanks for posting in Intel communities.
Could you please get back to us with the one API version, the Intel MKL version, a sample reproducer, and steps to reproduce so that it helps us in looking your issue further and assist you accordingly?
Shanmukh.SS
ShanmukhS_Intel
Hi Qbin.
It seems you were unable to reply to this thread based on your description mentioned in the below link(which was created newly), We would like to inform you that we would be monitoring and replying to the thread in the below link itself and closing this thread.
https://community.intel.com/t5/Intel-oneAPI-Math-Kernel-Library/Reply-to-Shanmukh-SS/m-p/1493118#M34639
Shanmukh.SS
