an accuracy problem between MKL and MATLAB
shaopeng_z_
초급자
1,672 조회수
Dear all,
rencently,I have run a program  using Intel MKL sparse format and MATLAB respectively.I find an accuracy problem in my result. Let me briefly summarize what I did.
At first,I use the MKL libary to compute K*X=KX ,as follows:
the full format symmetric matrix K converts to the sparse format CSC (COPPTR,ROWIND,VALUES or ROWIND,VALUES,pointer_B,pointer_E)
program exe101
implicit none
integer::i,j
integer,parameter::DP=8
integer::nRows,nNonzero
integer,allocatable::COPPTR(:),ROWIND(:),pointer_B(:),pointer_E(:)
real(kind=DP),allocatable::VALUES(:)
real(kind=DP),allocatable::X(:),KX(:)
real(kind=DP)::alpha,beta
character(6):: matdescra
open(unit=10,file='nRows.txt')
read(10,*)nRows
close(10,status="keep")
open(unit=10,file='nNonzero.txt')
read(10,*)nNonzero
allocate(COPPTR(nRows+1))
open(unit=10,file='COPPTR.txt')
read(10,*)COPPTR
allocate(ROWIND(nNonzero))
open(unit=10,file='ROWIND.txt')
read(10,*)ROWIND
allocate(VALUES(nNonzero))
open(unit=10,file='VALUES.txt')
read(10,*)VALUES
allocate(X(nRows))
allocate(KX(nRows))
X=1.0
alpha=1.0
beta=0.0
matdescra='SLNF'
allocate(pointer_B(nRows))
allocate(pointer_E(nRows))
do i=1,nRows
pointer_B(i)=COPPTR(i)
pointer_E(i)=COPPTR(i+1)
end do
call mkl_dcscmv('N', nRows, nRows, alpha, matdescra, VALUES, ROWIND, pointer_B, pointer_E,X, beta, KX)
open(unit=10,file='KX.txt')
write(10,'(1X,1f40.21)')KX
end
output::
KX=
1999999999.999993562698364257812
-0.000006198883056640625
2000000000.000000000000000000000
0.000002384185791015625
0.000001907348632812500
Secondly,I use MATLAB to compute K*X=KX
output::
1999999999.99999
-6.19888305664063e-06
2000000000.00000
0
0
0
2.14576721191406e-06
1.90734863281250e-06
where
input::
K=
5.414213562373090e+009 0.000000000000000e+000 0.000000000000000e+000 0.000000000000000e+000 -2.000000000000000e+009 0.000000000000000e+000 -7.071067811865480e+008 -7.071067811865480e+008
0.000000000000000e+000 3.414213562373090e+009 0.000000000000000e+000 -2.000000000000000e+009 0.000000000000000e+000 0.000000000000000e+000 -7.071067811865480e+008 -7.071067811865480e+008
0.000000000000000e+000 0.000000000000000e+000 4.000000000000000e+009 0.000000000000000e+000 0.000000000000000e+000 0.000000000000000e+000 -2.000000000000000e+009 0.000000000000000e+000
0.000000000000000e+000 -2.000000000000000e+009 0.000000000000000e+000 2.000000000000000e+009 0.000000000000000e+000 0.000000000000000e+000 0.000000000000000e+000 0.000000000000000e+000
-2.000000000000000e+009 0.000000000000000e+000 0.000000000000000e+000 0.000000000000000e+000 2.000000000000000e+009 0.000000000000000e+000 0.000000000000000e+000 0.000000000000000e+000
0.000000000000000e+000 0.000000000000000e+000 0.000000000000000e+000 0.000000000000000e+000 0.000000000000000e+000 2.000000000000000e+009 0.000000000000000e+000 -2.000000000000000e+009
-7.071067811865480e+008 -7.071067811865480e+008 -2.000000000000000e+009 0.000000000000000e+000 0.000000000000000e+000 0.000000000000000e+000 2.707106781186550e+009 7.071067811865480e+008
-7.071067811865480e+008 -7.071067811865480e+008 0.000000000000000e+000 0.000000000000000e+000 0.000000000000000e+000 -2.000000000000000e+009 7.071067811865480e+008 2.707106781186550e+009
X=
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
I want to know why  two results are different  and how  to improve the accuracy of sparse(dense) matrix- vector.
Thank you,
0 포인트
5 응답
mecej4
명예로운 기여자 III
1,672 조회수
Such small discrepancies are to be expected, given that the result has some elements of the order of 2 billion, and some elements of the order of a millionth. That ratio of the two is about the same as that of 1.0 to machine epsilon in double precision, and we know well that the subtractive cancellation (that happens when the matrix-vector product is computed) leads to precision loss.
0 포인트
jimdempseyatthecove
명예로운 기여자 III
1,672 조회수
mecej4, why then does the 7th entry vary by a much larger factor? (was this a type-o by the OP?) Jim Dempsey
0 포인트
mecej4
명예로운 기여자 III
1,672 조회수
Jim, The coefficients of the matrix are all of the form (a + b/sqrt(2)) X 109, where a and b are small integers (plus or minus 0, 1, 2, 4). The M-V product should give 2 X 109 in rows 1 and 3, and zero in the rest of the rows. Relative to the non-zero coefficients, a sum such as 2 X 10-6 is about the same as 1 is relative to machine-epsilon. The non-zero values that the OP obtained will be sensitive to the order of evaluation. Compared to the exact value (zero), the values given by MKL and Matlab are equally bad (or good, depending on the point of view). The values in the file values.txt are not all given to the full number of digits that double precision permits. Correcting them caused the output KX(4:8) to become exactly zero, leaving KX(2) as the only number that is small instead of being identically zero.
0 포인트
John_Campbell
새로운 기여자 II
1,672 조회수
Given that: kx(i) = K(i,:) * x(:) . You could define vectors kx_16 and x_16 as real*16 and accumulate kx_16, for all available values of K(i,j). You would not need to store K, but merely obtain all non-zero values and accumulate their effect. You could then compare the error of kx_matlab and kx_mkl from kx_16 and report the sum of the absolute diference. . This would show which one is worse. As you would probably calculate this in a Fortran environment, you would need to be careful to extract kx_matlab to the precision available. You need to be careful to identify possible sources of error in the comparison and when obtaining values of K. The results might be an interesting study. John
0 포인트
Bernard
소중한 기여자 I
1,672 조회수
I suppose that catastrophic cancellation could be blamed for slightly inaccurate results.It mainly occurres when two very close values in precision(nearly equal) are subtracted or added with different signs. Moreover the exact implementation of an algorithms as beign used by Matlab and MKL can also be different thus leading to miniscule variation in the final result.
0 포인트
응답
