7303 Discussions
best way to investigate difference between debug and release when calling LAPACKE_dposv
Le_Callet__Morgan_M
Hello all.
I am using the function  LAPACKE_dposv in my c++code and when checking the return value it is not 0 in debug but it is in release.
Shall i be worried ?
Is there some obvious check i should do in my matrices
I am using the following code structure with my own matrix:
LAPACKE_dposv Example Program in C for Row Major Data Layout (intel.com)
Thanks and best regards
VidyalathaB_Intel
Hi Morgan,
Could you please share your project file with the sample reproducer code and steps to reproduce (if any) so that we could check it from our end?
Meanwhile, you can check for the details of the return value of the function here at this link
https://www.intel.com/content/www/us/en/develop/documentation/onemkl-developer-reference-c/top/lapack-routines/lapack-linear-equation-routines/lapack-linear-equation-driver-routines/posv.html
This function returns a value info.
If info = 0, the execution is successful.
If info = -i, parameter i had an illegal value.
If info = i, the leading minor of order i (and therefore the matrix A itself) is not positive definite, so the factorization could not be completed, and the solution has not been computed.
Could you please confirm if you have observed the same issue with the example code provided in the link?
A quick check of the example in the link from my end shows that the LAPACKE_dpsov function call returns 0 in Debug mode as well.
Additionally, please let us know the MKL version being used in this case and your OS environment details.
Vidya.
Le_Callet__Morgan_M
Dear Vidyalatha, many thanks.
I am still checking my matrixes to make sure it does not have any non finite number. Once down i ll update you.
Many thanks.
Morgan
VidyalathaB_Intel
Hi Morgan,
As we haven't heard back from you, could you please provide us with an update regarding the issue? Please get back to us with the above-mentioned details if the issue still persists.
Vidya.
Le_Callet__Morgan_M
Dear Vidyalatha, i have checked and the issue was with my code. This thread can be deleted.
Thanks and kind regards
Morgan
VidyalathaB_Intel
Hi Morgan,
>>i have checked and the issue was with my code...This thread can be deleted.
Thanks for the confirmation.
Please post a new question if you need any additional assistance from Intel as this thread will no longer be monitored.
Vidya.
Le_Callet__Morgan_M
Dear Dear Vidyalatha, the error was in my code; this thread can be closed and deleted. Thanks and kind regards.
