7222 Discussions
bug of sgemm, 2015 mkl gives wrong result, but 2013 gives correct
志强_赵_
The compile option of 2015:
/work1/soft/intel2015/composer_xe_2015.0.090/bin/intel64/ifort -i8 -openmp main.f90 -o i64_2015 -L /work1/soft/intel2015/composer_xe_2015.0.090/mkl/lib/intel64 -lmkl_intel_ilp64 -lmkl_core -lmkl_intel_thread -Wl,-rpath /work1/soft/intel2015/mkl/lib/intel64
The option of 2013
/work1/soft/intel/composer_xe_2013.0.079/bin/intel64/ifort -i8 -openmp main.f90 -o i64_2013 -L /work1/soft/intel/composer_xe_2013.0.079/mkl/lib/intel64/ -lmkl_intel_ilp64 -lmkl_core -lmkl_intel_thread -Wl,-rpath /work1/soft/intel/composer_xe_2013.0.079/mkl/lib/intel64
The 2013 gives 2.0000, but 2015 gives 0.000
The code is shown below
program testi8
  implicit none
  integer,parameter :: REL = 4
  integer,  parameter :: num  = 2500000000, one = 1
  real(REL),dimension(:,:),allocatable :: a, b, c
  integer :: i, j
  print*, "allocate arrays..."
  allocate(a(1, num ), b(num, 1), c(1,1))
  a = 0.0_REL
  b = 0.0_REL
  c = 0.0_REL
  print*, "value arrays..."
  do i = 1, num
     if(i.eq.1) then
        a(1,1) = 1.0_REL
     else if(mod(i, 2).eq.0) then
        a(1, i) = 1.0_REL
     else
        a(1, i) = -1.0_REL
     end if
     b(i, 1) = 1.0_REL
  end do
  call sgemm('n', 'n', one, one, num, 1.0_REL, a, one, b, num, 0.0_REL, c, one)
  print*, "result"
  print*, c
end program testi8
Gennady_F_Intel
thanks, we will check
Gennady_F_Intel
I see the same result too.
We will try to investigate the cause of the issue and will back with the updates.
thanks, Gennady
志强_赵_
In this case,If you set the a array to 1.0. Then call the sgemm. The desired result should be 2.5e9.
but both 2013 and 2015 give the wrong result. The 2013 say it's 1.6777e7. The 2015 say it's 1.6e9.
I think this is another situation. Please check it.
thanks, Gennady
Murat_G_Intel
These differences seem to be due to the round-off errors in floating point operations. Vectorization changes the order of operations, and instead of accessing the elements sequentially, vectorization may process the elements in strides. For example, in your use case (essentially a dot product) instead of summing the element-wise vector-multiplication sequentially, a vector register is used to accumulate the sums in different chunks. The elements of the vector register is accumulated to get the final result. This causes round off errors even for the cases where one would expect the summation will cancel each other such as (1, 1, -1, -1, 1, -1, 1, ...).
To verify this claim, I created a C code that demonstrates this issue when vectorization is turned on (-O2 and above):
#include <stdlib.h>
float sum(float* x, long long len) {
    long long i;
    float res = 0.;
#pragma vector aligned
    for (i=0; i<len; ++i)
        res += x;
    return res;
void main(int argc, char* argv[])
    long long i;
    long long N = 100;
    if (argc>1) N = 1000LL*atoi(argv[1]);
    float* a =  _mm_malloc(sizeof(float)*N, 128);
    printf("N=%ld \n", N);
    if (N<2) return;
    a[0] = 1;
    a[1] = 1;
    for (i=2; i<N; ++i) {
        if (i%2) a = 1;
        else a = -1;
    printf("Result = %f\n", sum(a, N));
    _mm_free(a);
icc main.c -O2 -xAVX -vec-report=6
$ ./a.out  20000
N=20000000
Result = 2.000000
$ ./a.out  200000
N=200000000
Result = 0.000000
If you compile the same program with -O1, we always get 2.0:
./a.out  2000000
N=2000000000
Result = 2.000000
