cblas_ddot access violation
Di_Luca__Daniele
I was just trying to learn how to use the 64 bit platform on Parallel Studio XE, when running a very simple example (using cblas_ddot() - as shown below)  I've got the following exception:
Exception thrown at 0x00007FF7AA60EB36 in mkl64bit.exe: 0xC0000005: Access violation reading location 0xFFFFFFFFFFFFFFFF.
Then I tried the Intel Inspector tool and it says there was an invalid memory access: 0x1eb36    vmovsd xmm4, qword ptr [r9+rax*8]
The code is:
int main() {
    double v1[3], v2[3];
    for (size_t i = 0; i != 3; ++i)
        v1 = v2 = 1.5;
    double result;
    result = cblas_ddot(3, v1, 1, v2, 1);
    return 0;}
I'm using Intel Parallel Studio XE Cluster Edition 2019 for Windows on Visual Studio 2017.
May you please help me to understand what's wrong and how could I fix the problem?
Thanks in advance,
Daniele
Gennady_F_Intel
Everything looks correct. How did you build this example? You may take a look at the existing ddot examples into <mkltoot>\examples\cblas\source\
Di_Luca__Daniele
I figured it out I was linking mkl_intel_ilp64.lib without the /DMKL_ILP64 option for the compiler and when I switched to the automatic linking through the Intel Performance Libraries option, I kept linking mkl_intel_ilp64.lib, instead of mkl_intel_lp64, but I forgot to turn on the “Use ILP64 interfaces” flag too. I've screwed it up a little bit, but now it seems to work fine,
thanks for the support,
Daniele
Gennady_F_Intel
Daniele, thanks for keeping us inform. We always recommend to see mkl examples which will greatly help to mitigate such problems as well.
