The attached code crashes on my core I7 machine which runs ubuntu 9.10 64 bits.
Hagai.
[cpp]#include#include #include #include #include #include #include #include #include using namespace std; #define NUM_ITEMS 1 #define NUM_WEIGHTS 100 #define NUM_OUTPUTS 25 #define NUM_CYCLES 50 void PrintMatrix(double* pMatrix, const size_t nRows, const size_t nCols) { for (size_t i=0; i<< pMatrix[i * nCols + j] << 't'; } cout << endl; } cout << endl; } void PrintLowerTriangularMatrix(double* pMatrix, const size_t nRowCols) { for (size_t i=0; i<=i; ++j) { cout << pMatrix[i * nRowCols + j] << 't'; } cout << endl; } cout << endl; } void CreatePascalMatrix(double* const pMatrix, const int nWidthHeight) { for (int i=0; i<< "P:" << endl; PrintMatrix(P, NUM_WEIGHTS, NUM_OUTPUTS); int nNumOutputs = NUM_OUTPUTS; char chUplo = 'L'; int nInfo; CreatePascalMatrix(S, NUM_OUTPUTS); cout << "S:" << endl; PrintMatrix(S, NUM_OUTPUTS, NUM_OUTPUTS); dpotrf( &chUplo, &nNumOutputs, S, &nNumOutputs, &nInfo); cout << "S Cholesky:" << endl; PrintLowerTriangularMatrix(S, NUM_OUTPUTS); cblas_dtrsm(CblasRowMajor, CblasRight, CblasLower, CblasTrans, CblasNonUnit, NUM_WEIGHTS, NUM_OUTPUTS, 1, S, NUM_OUTPUTS, P, NUM_WEIGHTS); cout << "X:" << endl; PrintMatrix(P, NUM_WEIGHTS, NUM_OUTPUTS); // multiply to check result cblas_dtrmm(CblasRowMajor, CblasRight, CblasLower, CblasTrans, CblasNonUnit, NUM_WEIGHTS, NUM_OUTPUTS, 1, S, NUM_OUTPUTS, P, NUM_WEIGHTS); cout << "P:" << endl; PrintMatrix(P, NUM_WEIGHTS, NUM_OUTPUTS); } int main() { CalculateGain(); return 0; } [/cpp]
Hagai.
hagai,
at the first glancethis code isn't compiled:
- for(size_ti=0;i<
- the same with PrintLowerTriangularMatrix ..
- CalculateGain() ????
How the input Matrixinitialized?
Can you create thefull version of the test(plus the input data ) and attach it to this thread?
--Gennady
OK, so this is another bug in your code editor... I pasted my code into the forum's code editor after compiling it and it changed it to the version you see above. I'll attach it as a file, you can paste from the attached file and see that it happens.
There is no additional data... the input matrix to dtrsm is a cholesky factor of a pascal matrix, initialized by the CreatePascalMatrix function.
Hagai.
Hagai.
Quoting - hagai_sela
Hagai.
Hagai.
allocating the output array by the following
//double P[NUM_WEIGHTS * NUM_OUTPUTS];
double P[NUM_WEIGHTS * NUM_WEIGHTS];
eliminates the problem
--Gennady
Quoting - Gennady Fedorov (Intel)
--Gennady
a - I increased the array size to NUM_WEIGHTS * NUM_WEIGHTS, and it still crashes.
b - I am not sure I follow... Are you suggesting this as a workaround or a bug fix?
The equation is XA=B.
A is a NUM_OUTPUTS * NUM_OUTPUTS matrix, B is a NUM_WEIGHTS * NUM_OUTPUTS matrix, therefore X should also be a NUM_WEIGHTS * NUM_OUTPUTS matrix.
Hagai.
