10.2.2 VML vdCosh error code
jaewonj
It seems MKL 10.2.2 VML vdCosh does not return the correct error code. In the following example, I expect an error code of VML_STATUS_OVERFLOW (which is the case with MKL 10.1) but 10.2.2 vdCosh returnsVML_STATUS_OK.
1) I used default modes.
2) Tested on 64-bit Linux (Ubuntu 9.04).
Are there any options I need to set?
Jaewon
MKL_INT n =2;
double a[2] = {-709.0578, 0.0}, y[2];
vmlClearErrStatus();
vdCosh(n, a, y);
err = vmlGetErrStatus();
Gennady_F_Intel
Jaewon,
It looks like the problem with the latest version.I 've got the similar result on win32.
We will check the problem more more carefully and will back.
--Gennady
Yury_Antimirov
Jaewon,
vdCosh(-709.0578) is a normal floating point double precision value, there's no overflow, so MKL reports VML_STATUS_OK. It was an error in MKL 10.1, which was fixed in MKL10.2.2
--Yury A--
jaewonj
Jaewon,
--Yury A--
Thanks Gennady and Yury.
It's good to hear that this has been fixed in version 10.2.2.
It seems cosh(-709.0) = 4.1092 * 10^307.
Then why vdCosh(-709.0) returns INF?
Please compare vdCosh(-709.0) with cosh(-709.0).
Jaewon
Yury_Antimirov
Hello Jaewon,
Thank you for clarification. Indeed MKL 10.2.2 fixes the some problems with flagging overflow in vdCosh. Unfortunately there is no complete fix in 10.2.2 yet. So you will still see wrong INF returns on some arguments around overflow bounds (~+/-710.47586). Complete fix is expected in next MKL update release.
Yury A.
