cblas_zsyrk returns wrong results
Collins__Andrew
I have the following function and I'm trying to compute C = A*A' using zsyrk from blas, but when I print the C matrix the results are wrong. What am I missing?
double* zsyrk(int N, double *A) {
	int i,j;
	int K;
	K = N;
	const int * alpha;
	int a = 1;
	alpha = &a;
	int lda = N;
	int ldc = N;
	const int * beta;
	int b = 0;
	beta = &b;
	double *C;
	C = (double *)calloc( N*N, sizeof(double));
	for (i = 0; i < N; i++){
		for(j = 0; j < N; j++){
			printf("%lf ", A[i*N + j]);
		printf("\n");
	cblas_zsyrk(CblasRowMajor, CblasUpper, CblasTrans, N, K, alpha, A, lda, beta, C, ldc);
			printf("%lf ", C[i*N + j]);
		printf("\n");
	return C;
The restults are:
Matrix A:
-662.059957 -942.824833
545.621059 -270.699577
Matrix C:
-0.000000 0.000000
0.000000 -0.000000
Ying_H_Intel
Hi Andrews,
are the array A complex number or double array?
How about try cblas_dsyrk  to replace the cblas_zsyrk
Ying
BLAS routine names have the following structure:
<character> <name> <mod> ( )
The <character> field indicates the data type:
s real, single precision
c complex, single precision
d real, double precision
z complex, double precision
G__Petru
Hej,
First of all please read the documentation more careful next time.
Instead of int declare both  constants, alpha and beta, as double
e.g.
const double * alpha;
09     double a = 1;
10     alpha = &a;
Also, in order to calculate C as C = A*A' (+yada yada) ,  you have to use CblasNoTrans instead of CblasTrans (check the documentation).
Now everything will work just as intended.
Petru
G__Petru
Hej,
First of all, please read the documentation[0] more carefully next time.
In order to calculate correctly you have to:
1. change the alpha and beta constants from int to double.
e.g.
1     const double * alpha;
2     double a = 1;
3     alpha = &a;
4
5     const double * beta;
6     double b = 0;
7
    beta = &b;
2. change CblasTrans to CblasNoTrans (check the documentation[0])
[0]:https://software.intel.com/en-us/mkl-developer-reference-c-cblas-syrk
Petru
