hello,
I would like to solve a linear system of type Ax = b with A,B and x in the file joined.
The matrix A is well-conditioned, so I must be wrong with the iparms :
357 iparm[0] = 1; /* No solver default */
358 iparm[1] = 2; /* Fill-in reordering from METIS */
359 iparm[2] = 8;
360 iparm[3] = 0; /* CGS */
361 iparm[4] = 0; /* No user fill-in reducing permutation */
362 iparm[5] = 0; /* Write solution into x */
363 iparm[6] = 0; /* Not in use */
364 iparm[7] = 0; /* Max numbers of iterative refinement steps */
365 iparm[8] = 0; /* Not in use */
366 iparm[9] = 13; /* Perturb the pivot elements with 1E-13 */
367 iparm[10] = 1; /* Use nonsymmetric permutation and scaling MPS */
368 iparm[11] = 0; /* Not in use */
369 iparm[12] = 0; /* Not in use */
370 iparm[13] = 0; /* Output: Number of perturbed pivots */
371 iparm[14] = 0; /* Not in use */
372 iparm[15] = 0; /* Not in use */
373 iparm[16] = 0; /* Not in use */
374 iparm[17] = -1; /* Output: Number of nonzeros in the factor LU */
375 iparm[18] = -1; /* Output: Mflops for LU factorization */
376 iparm[19] = 0; /* Output: Numbers of CG Iterations */
377 iparm[27] = 1; /* check the data structure */
378 iparm[31] = 1; /* iterative solver*/
380 maxfct = 1; /* Maximum number of numerical factorizations. */
381 mnum = 1; /* Which factorization to use. */
The Package ID of mkl is : l_mkl_p_10.0.011
Thanks for any help you can give me
Antoine
链接已复制
tar: Ignoring unknown extended header keyword `SCHILY.dev' tar: Ignoring unknown extended header keyword `SCHILY.ino' tar: Ignoring unknown extended header keyword `SCHILY.nlink'
